I only tried it with the slug coil inside (i.e. towards the neck) and the screw coil outside. But you are right, if the screw coil is the one with more turns that could explain the thinner tone I was hearing. The wire is long enough so that would be easy to try. I will report on the results when I get around to try this.
Thanks for the tip,
Stephan
