Author Topic: Ed Roman's 22 vs 24 Fret opinion! Anyone have an opinion also?  (Read 16547 times)
AnnunakiMassacr
« on: October 07, 2012, 06:42:09 PM »
Well I was basically researching this subject and came across this article which I found very interesting.does anyone have any comments on this?
http://www.edroman.com/techarticles/22vs24.htm
Here's the article copied and pasted, too:
This is a debate that many people avoid, In fact many companies just look the other way. Normally a progressive company looking to make a name for themselves will tool up so that they can do 24 fret necks.  (PRS did it back in 1985). I have alienated some players away from me with commentary and reviews like this. But facts are facts, and facts don't lie, and this is not conjecture, it is scientific proven fact.
It’s a shame, that it's a little known fact that ALL PRS GUITARS up to 1993 were all 24 fret. PRS made the best guitars they ever produced as 24 fret models.
The Laws Of Physics are Absolute click here.
It is my opinion that PRS wanted to appeal to the older crowd when they started offering a 22 fret neck in 1994. They wanted a Jeff Beck or an Eric Clapton. These older geezers (I say that respectfully) are all still using 22 fret guitars.  I mean, when do these guys ever get to go into a music store and check out gear. It just doesn’t happen.
Usually they are behind the times and nobody will tell them because they are so famous and considered Guitar Gods.  I went to see the Rolling Stones recently. I would love to spend an afternoon with Keith Richards, He is using the most antiquated gear on the planet. I understand that maybe he has a retro image to uphold, but that's no reason to play a guitar that is obviously limiting his capabilities.
I personally have talked to at least 15 of these guys over the years and I have concluded that most of them have acquired their last guitars. Many of these guys simply aren’t concerned as much about gear as they once were. So PRS briefly had Dickie Betts, Eventually Dickie went back to his old faithful Kalamazoo made Gibson. They never did get a Page, Beck or a Clapton and as far as I’m concerned they probably never will. Unless of course Fender buys PRS and introduces these guys to the intelligent reasons to play 24 Frets.
I have personally talked to Ace Frehley about it at least 50 times. It's almost a joke between us at this time. Ace has the attitude that he "doesn't want to be confused with the facts, He's already made up his mind," and that's that.
I can't fight that logic!!!!   I spoke to Zakk Wylde about exactly the same thing and I was met with a similar mindset.  For this reason I believe PRS decided to build their single cut, Their McCarty and Custom 22.  There are a lot of diehard, dyed in the wool, Les Paul fans out there. I personally believe that a Les Paul has it's place, just not in my hands.  (Unless I am cutting into it)
It is costlier to do 24 fret necks, Most companies that sell pre slotted fret boards will only supply 22 fret necks,  If you purchase any fret slotting machinery you will immediately notice that the arbors are usually set up for 22 frets and if you want any oddball scales you will probably have a devil of a time trying to buy it. (oddball means anything other than Fender or Gibson).       The Laws Of Physics are Absolute click here.
I prefer 24 frets, for a lot of reasons, the most important being, the rhythm pickup has to be installed off axis where the 24th fret would normally fall.  On a 22 fret neck the pickup sits directly over the 24th fret harmonic node. Simply explained a node is a dead spot or a massive phase cancellation.     The Laws Of Physics are Absolute click here.
These nodes occur on the 7th fret, 12th fret, 19th fret and 24th fret. If you place a pickup directly on a node the midrange frequencies will cancel themselves out. Make sure you avoid a guitar that the node falls on the pickup.  Unless of course you want a muddy distorted rhythm sound like you would normally experience with a Les Paul or any Les Paul type guitar.  Most intelligent people will agree on the fact that a Les Paul has a nice meaty lead tone but chords sound like dung.    (Check out the 24 Fret Maximus or the 24 Fret Turner Model 1) Nothing out there in a single cut guitar comes close.
I prefer to play a guitar that will give me the best of both worlds. If you take a well made 24 Fret guitar PRS, Baker, Quicksilver,  or otherwise. If the pickups, bridge & neck are acoustically coupled you will be able to achieve an even fatter, meatier, browner, darker, creamier sound by turning the tone to zero on the neck pickup and turning the volume control on the guitar all the way up.
I guarantee I can make an early 24 fret PRS Classic sound just like a Les Paul plus get the added attraction of a 335 a Strat, a Tele and even a Jazz Guitar. PRS has taken that guitar off the market around 1995. I believe they did it on purpose so they could sell more guitars. It is self defeating to make a guitar that does everything.
Factoid 1: A typical Les Paul will always sound muddy when you play chords !!!!!
Factoid 2: A Typical Les Paul is NEVER capable of sounding like a Strat or a Tele. !!!!!
Factoid 3: PRS broke that barrier in 1984 with the introduction of their 24 Fret, 25" Scale handcrafted guitar,
Factoid 4: PRS further improved on it in 1989 with the introduction of the Classic 24.
Factoid 5: PRS redesigned the Classic 24 in 1995 and basically destroyed the best guitar ever made to date.
Factoid 6: I don't think they will ever bring that one back. So I designed the Quicksilver a guitar that was built based on many of the influences of the now defunct Classic 24.
 So far I have only given one reason
why I like the 24 fret models better.
Of course, I like the added reach of the two extra frets and the easier facilitation of all the high notes. Plus the visual aid of the double octave marking is a big help in playing.
The neck angle is better on the PRS models with 24 frets than with 22, the string tension is slinkier and the overall playability is far better.
24 frets is the wave of the future, 22 frets is the older way. All the new cool guitars have 24 frets.  Gibson has finally jumped on the band wagon. Gibson has offered a double cutaway Les Paul with 24 frets. for under $2,000.00!!!   Sadly it still uses a Rosewood fingerboard, plastic inlays, and a limited reach. They have stayed with their same old tired 24 3/4 scale. Gibson is your Grandfather's Guitar !!!!!!!
 Important Note
Some companies are now trying to pull the wool over your eyes by simply taking a 22 fret neck and adding 2 more frets to it.  I will be exposing them in a new Expose' section coming soon on the website. At this writing I suspect that Gibson simply extended the board a little longer, The scale is still the same.
Don't be fooled look for a 25" scale and a true double octave 24 fret neck that is not just an overhang on the neck.
« Last Edit: October 07, 2012, 06:45:37 PM by AnnunakiMassacr »
BKPs: ESP Eclipse I CTM FT w/Riff Raff bridge/Mule neck - ESP Eclipse I CTM w/Rebel Yells - LTD EC-1000 FT w/Aftermaths - Music Man JPIX w/Juggernauts
Re: Ed Roman's 22 vs 24 Fret opinion! Anyone have an opinion also?
« Reply #1 on: October 07, 2012, 06:50:11 PM »
This one has been done before. Here it is:
https://bareknucklepickups.co.uk/forum/index.php?topic=22293.0
 :D
itamar101
« Reply #2 on: October 07, 2012, 09:26:34 PM »
 :lol: :lol:
This is the most bullshiteeee thing I've read all month.
1) "A typical Les Paul will always sound muddy when you play chords !!!!!"
Just get good pickups and no guitar will sound muddy in the neck position. PRS don't usually use good pickups anyway so they're muddy in the neck position.
2) "A Typical Les Paul is NEVER capable of sounding like a Strat or a Tele. !!!!!"
Haha! And a PRS sounds exactly like one, doesn't it! I'm sure 24 frets helps for that - because obviously strats and teles use 24 frets too! :P
What does this even have to do with the argument? It has nothing to do with whether 24 frets are better! Les Pauls aren't even meant to sound like Strats and Teles! Thats the point! And a strat doesn't sound like a tele or les paul either! They're MEANT to be different! Not some jack of all trades... They're meant to be the ace of one!
Already, It's obvious that this is just some Gibson hater (love to hate, huh) :lol: + PRS fanboy giving his stupid opinion on why he is right and every professional in gibson is wrong.
3) "PRS broke that barrier in 1984 with the introduction of their 24 Fret, 25" Scale handcrafted guitar."
What about Jackson? Or any other "metal guitar builder"? I'm sure they did it beforehand...
4) "I guarantee I can make an early 24 fret PRS Classic sound just like a Les Paul plus get the added attraction of a 335 a Strat, a Tele and even a Jazz Guitar. PRS has taken that guitar off the market around 1995. I believe they did it on purpose so they could sell more guitars. It is self defeating to make a guitar that does everything."
:lol: Haha! what a $%&#ing idiot. I should've stopped reading here.... Also, how does this contribute to the point of the article? Now he's just trying to sell PRS guitars! 24 frets certainly doesn't help it sound like a 22 fretted instrument!
5) "PRS redesigned the Classic 24 in 1995 and basically destroyed the best guitar ever made to date."
This man is gonna put in in a coma. Simple as it sounds. Still doesn't contribute to the article, either.
6) "Of course, I like the added reach of the two extra frets and the easier facilitation of all the high notes. Plus the visual aid of the double octave marking is a big help in playing."
HEY!! He said something reasonable! All preference. I generally don't use 24 frets, so if i find a guitar that has every thing that i want except for 24 frets, I'm not really gonna care at all. This is coming from someone who uses both.
7) "24 frets is the wave of the future, 22 frets is the older way. All the new cool guitars have 24 frets.  Gibson has finally jumped on the band wagon. Gibson has offered a double cutaway Les Paul with 24 frets. for under $2,000.00!!!   Sadly it still uses a Rosewood fingerboard, plastic inlays, and a limited reach. They have stayed with their same old tired 24 3/4 scale. Gibson is your Grandfather's Guitar !!!!!!!"
Whose to decide what is cool? Show me a prs custom 24 for under $2000.
8) "Most intelligent people will agree on the fact that a Les Paul has a nice meaty lead tone but chords sound like dung."
Intelligent? Someone's intelligent just because they agree with you - a shitety PRS fanboy in a shitety attempt to market their products?
All in all, this man is stupid. Thats it.
More than half of the article was off-topic and based on hating on gibson.
This was almost as bad as those people who fight over whats better, fender or gibson!
Don't get confused, I think that PRS are great, but this person is horrendously biased for the worst reasons.
EDIT: Made my post much easier to read, structure-wise :D
« Last Edit: October 07, 2012, 10:06:22 PM by itamar101 »
Lezard
« Reply #3 on: October 07, 2012, 09:32:59 PM »
Agreed, Gibson is clearly better.
itamar101
« Reply #4 on: October 07, 2012, 09:37:23 PM »
 :lol: :lol:
I was actually contemplating saying :D
But really, I just prefer the feeling of gibsons. Nothing to do with what is "better".
Lezard
« Reply #5 on: October 07, 2012, 09:48:43 PM »
 :lol: :lol:
Agreed again, I love the sound of a good tele or strat, but something about the neck radius or bridge placement usually doesn't suite me. I'm not too fond of Gibson as a company but I do love the guitars.
I guess if push came to shove I'd get a cheaper asian guitar or something handmade closer to home, depending on bank balance rather than go for one of the big two.
« Reply #6 on: October 07, 2012, 10:40:31 PM »
Typical of Ed Roman to back up his argument - which is nothing more or less than a personal opinion - by repeatedly saying "The Laws Of Physics are Absolute click here".  :roll:
Personally, I think the neck pickup on a 22-fret guitar sounds better than the neck pickup on a 24-fret guitar (I'm not including SGs there, because the neck pickup is in the same position it'd be if there were 24 frets!).  I sold two PRS Miras because, ultimately, I wished they had 22 frets instead of 24.
And all his talk about how chords sound on a Les Paul.... most rock players will play chords on the bridge pickup 99% of the time, so the number of frets and placing of the neck pickup is totally irrelevant.
And for those who play 24-fretters - how much do you actually use those top two frets?
« Reply #7 on: October 07, 2012, 11:21:04 PM »
Philly has some good points there. I don't own a Gibson nor a PRS (at the moment...) but had a JEM 77FP in the past and I didn't use those two extra frets much. Could be a lack of skills... Personally I prefer 22 frets, it feels more natural.
The debate whether Gibson or PRS is better, seems irrelevant to me. Heard great sounds from both brands in the hands of skilled players. They're just different birds.
« Last Edit: October 08, 2012, 11:52:56 AM by Telerocker »
« Reply #8 on: October 07, 2012, 11:28:42 PM »
I thought 'that looks like the sort of thing I'd argue with'
Then didnt read it, saw the link to the previous thread, saw that I argued with it, scanned it and my arguments and agreed with myself.
What ed roman knew in life about physics could have been written on the back of a stamp with room to spare.
« Reply #9 on: October 08, 2012, 04:30:55 AM »
ed roman is complete douche who sees himself as a genius and some sort of messiah
his articles are so full of cr@p that are only worth reading for a good laugh, but this also gets boring at some point
he paints regular $70 seymour duncans and then sell them for $140 as custom shop pickups :lol: :lol: :lol: :lol: :lol:
« Reply #10 on: October 08, 2012, 07:42:48 AM »
is it that time again :(
« Reply #11 on: October 08, 2012, 11:47:48 AM »
I suppose it's inevitable that any guitar player with an internet connection will, at some point, discover the late Ed Roman's world of ill-informed opinion and blingy-tat guitars.
« Reply #12 on: October 08, 2012, 01:28:48 PM »
All of Ed's arguments were only there to point towards whatever he was selling or having made.
Sometimes he would even contradict himself if what he was selling went against the grain of what he'd promoted previously
He did make a few valid points in the midst of the BS he spouted, but in the end it became a bit transparent that he was just pushing sales of his own lines.
TheyCallMeVolume
« Reply #13 on: October 08, 2012, 02:26:23 PM »
Completely biased and wrong.
« Reply #14 on: October 08, 2012, 02:32:03 PM »
ribs is ribs
