Coil Tapping / Pinch Harmonics
Started by CaffeineJunkie, February 21, 2006, 05:45:36 PM
Elliot
Its a fingerstyle technique (although I can't see why you could'nt do it if you use a pick) so you use your picking hand to generate the harmonic.
jimi hendrix
Quote from: sambomaybe i do...  :wink:  !  :o   :D
Yeah, but you know what they say about men with foot long hands... :D
sambo
Neemo
Quote from: ElliotI dont think pinch harmonics are the same as artificial harmonics - at least not in the acoustic guitar world - artificial harmonics are where you play the harmonic (usually) 12 frets above a fretted note so you get the effect of a 12th fret harmonic but , i.e. if you fret the second string you can play the '12th fret' harmonic on the 14th fret.
I thought that was tap harmonic? Or atleast that's what Satriani calls them.
slow music for slow people
Artificial harmonic: retting a note and playing a harmonic from that using the picking hand to touch the harmonic out. As previously said.
Tapped harmonic: As I understand it a tapped harmonic is where you tap a note that is a harmonic of the fretted note, but you tap it on top of the fret, so you get a harmonic sound thats sounded with a tap.
^total guitar (the mag) sometimes confuse things by calling "harp harmonics" artificial harmonics, while the USA mags use pinch and artificial interchangeably.
but yeah, tapped harmonics are what mark/mdv said.
I dunno, i just know what the techniques are :D
genocidal tendencies
I could be wrong, but I think tapped and pinch harmonics are both types of artificial harmonic - artificial in that they aren't natural.
lulusg
Actually they very unnatural...and artificial.  :)
Just passing by
CaffeineJunkie
oh right, cool. Wasn't expecting quite a response but hey, always helps to have more than one opinion.
Cheers
Geno: you could tap a natural harmonic.
Isn't it still technically a natural harmonic though, being on an open string, whereas tapped harmonics have to be fretted?
lulusg
...please disregard my input! No idea what I was talking about...tried to be funny but it didn't work out! :shock:
Just passing by
