Author Topic: 80's Rock ??  (Read 6475 times)
Copperhead
Re: 80's Rock ??
« Reply #15 on: November 26, 2012, 01:59:20 PM »
Nailbomb is very similar to Tone Zone, just sounds better!
I use both/either in all of my guitars.
Re: 80's Rock ??
« Reply #16 on: November 26, 2012, 02:50:00 PM »
IMO - the Nailbomb needs a really bright sounding guitar to excell - or else the extra low mids it has makes it sound a bit sludgy.
Another vote for the VH2 as a great all-round 80s rock pickup - especially the first half of the 80s, whilst the Miracle Man suits the tail end of the 80s when guitar sounds got a bit more saturated.
If the guitar were a bit dark or beefy sounding or you like a crisp sound then the Cold Sweat might appeal - although if Tone Zone suits you already then maybe not = look at Miracle Man instead
Copperhead
Re: 80's Rock ??
« Reply #17 on: November 26, 2012, 04:41:33 PM »
Having very bright guitars; bolt-on, 25.5, maple necks.... I will stand by the Nailbomb to TZ comparison. Either pup in the same guitar will EQ nearly identical, and both pups share the affinity for pinch harmonics and controlled feedback. I concur with Feline that I do not like the Tone Zone in anything but bright guitars as it gets muddy fast.
The TZ has a higher output than the Nailbomb, but the wondrous thing about the Nailbomb is that it generates a high gain tone that sounds as if it has more output than it really does. Nailbomb sounds better clean than the ToneZone. Nailbomb in the bridge with a single coil in the neck creates a great middle position clean tone, whereas the Tone Zone because of the high output gets a little overbearing in this application.
Re: 80's Rock ??
« Reply #18 on: November 26, 2012, 05:00:42 PM »
At the risk of repeating myself for about the twentieth time  :oops: , the TZ was horrible in an SG and a Gordon-Smith LP Junior type.
But I can imagine it being a lot more suited to a bright bolt-on.
Re: 80's Rock ??
« Reply #19 on: November 26, 2012, 11:37:26 PM »
I had a Tonezone T in a Yamaha Pacifica Mike Stern-model. I don't like to bully other brands, but it was one of the worst pickups I had, I'm afraid. It did'n't work for me. Muddy, weak dynamics, cleaning up made it flat in tone, etc.
shampoch
    • Guitar & Amp Collection
Re: 80's Rock ??
« Reply #20 on: November 27, 2012, 12:13:32 AM »
If it helps guys, the Pickups will go into a bolt on Wolfgang type guitar, lightweight, and I will be splitting the coils as I do with another tone zone equipped guitar. I am leaning toward the VHII based on the Van Halen tone is what I am really after. The feedback here has been fantastic by the way....
My Collection:
www.GuitarHalo.com
Re: 80's Rock ??
« Reply #21 on: November 27, 2012, 12:18:09 AM »
You will love the VHII, especially the noteseparation, punch and picking dyamics, even with highgain.
shampoch
Re: 80's Rock ??
« Reply #22 on: November 28, 2012, 12:41:48 AM »
...after all your feedback and much thought going to go with the Holy Divers! I am sure it wont be my last set of BKs.
My Collection:
www.GuitarHalo.com
darrenw5094
Re: 80's Rock ??
« Reply #23 on: November 28, 2012, 12:55:35 AM »
To be honest, the VHII and Holy Diver would both work.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
Re: 80's Rock ??
« Reply #24 on: November 28, 2012, 01:35:18 AM »
The Diver is a good choice too.
Cpt_Gonzo
Re: 80's Rock ??
« Reply #25 on: November 30, 2012, 03:16:32 PM »
Yep, the Diver never lets down.
But it needs time to settle with you and the guitar, adjustment - wise.
(Actually, the one I have in my LP sounds thinner, in the Band mix, than the one in my Ash/ maple Strat. Acoustically, the Strat is brighter. Almost sure it's a height/ polepiece issue)
Alex
Re: 80's Rock ??
« Reply #26 on: November 30, 2012, 03:35:25 PM »
+ 1
The Tone Zone really is difficult to compare, I haven't found another pickup that sounds like it. It is probably the only DiMarzio humbucker I can not only stand, but also appreciate.
Re: 80's Rock ??
« Reply #27 on: December 02, 2012, 01:46:48 PM »
the alnico MM has close specs and voicing to the tone zone
they won't make it in 53mm spacing, though
darrenw5094
Re: 80's Rock ??
« Reply #28 on: December 02, 2012, 02:18:04 PM »
What pickup?
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Re: 80's Rock ??
« Reply #29 on: December 02, 2012, 02:42:23 PM »
What pickup?
The alnico Miracle Man.  It's actually the MM neck model, so only available with 50mm spacing.
