The character of the Vox vs Marshall is very different. AC/DC is all about cranked Marshalls. You're not going to get an AC30 to sound like that, although if you get a proper AC30 and crank it up it might well still sound cool. The point is between those sounds you're after you'll need to strike a compromise.
Also, just like Tekbow pointed out that the MG50 DFX isn't really anywhere near a benchmark for the marshall valve sound, the Vox Valvetronix etc is nowhere near the AC30 sound. I used to rehearse with a valvetronix (cant remember the model) on a regular basis and I have to say, hands down, those heads are the worst sounding and worst constructed amplifiers I have ever used and using it with a tubescreamer won't make a difference because the the solid state preamp in something like a valvetronix won't react in the same way as a AC30 valve preamp at all.
I feel like you may as well go for a line 6 modelling combo of some description, which probably isn't much different to the amp you have now, but it might just sound better. Or find a pod or something and use it in front of your current amp just to increase the range of sounds you can get.
Nothing but cranked valves sounds like cranked valves.
