Author Topic: Arrived: awesome piece of kit, about bloody time..  (Read 20009 times)
Brow
Re: Incoming: awesome piece of kit
« Reply #15 on: February 24, 2013, 10:57:17 PM »
amke sure it has the firmware update, apparently it makes a difference, although the ones i played were the original firmware and i thought it sounded great :)
Cheers for the heads up.
The Morpheus site is no more, and hasn't been for a while apparently, but I've managed to get a copy of the Firmware update from somewhere else so I'll have to see how it goes.
tekbow
« Reply #16 on: February 24, 2013, 11:03:40 PM »
http://morpheusefxsite.abff.stackablehost.com/download.php
Cached page i think, but the download still works. It says 2.1 but its a typo, it's 1.2
tekbow
« Reply #17 on: February 27, 2013, 07:08:30 PM »
Got here! A day late, but thats couriers for you..
So it came preinstalled with the firmware update, and no USB cable, which is fine, had a bunch of them anyway and i don't think we'll be seeing anymore updates in the near future..
So basically it's as i said it was before, down to a full step, no latency issues and no artificiality. It does become progressively "synthier" the further down you drop after this, but as i recently found out, the further you move away from the guitars tuning, the harder the DSP chip has to work, so fair enough. like i said, im not looking to go anyfurther than a 1 step. and to my mind, even at the largest drop, it doesn't sound anymore processed than a lot of metal produced with DI and re-amping..
No losses in volume, although with single coils on a strat i basically had to dime the input sensitivity knob on the back (in the instructions, it says turn this up until the LED guage on the front barely flashes yellow). obviously there was a bit more power with buckers.
The only minor minor little tiny thing i would say is this. When you activate it, there is just the most barely perceptible loss of presence, not treble as such, but like somebody dialled down the presence knob on an amp a tiny amount. It deadens ever so slightly, and i figure if you're telling people about these, you need to tell them about the (barely) bad. Its more to do with dynamics more than treble content.
In real terms, it doesn't do this anymore than a compressor might (never used one) or anymore than switching between one guitar and another might. It certainly doesn't prevent pinch harmonics in the neck or bridge positions of a strat with texas specials (yes i like em), you can hear the difference when you dig on notes and get more grit, it may soften the attack only just perceptibly, but it doesn't destroy it like a lot of people would have you believe. And it certainly doesn't affect any of this anymore than any other addition to the chain between you guitar and amp would.
One other thing to mention, and its not the pedals fault. play with a half decent amount of volume, because if you can still hear your electric strings played acoustically in standard tuning in combination with the drop tuning from the pedal thru the amp, it sounds weird. some people in the early days of the pedal thought it was the pedal producing this and duly rubbished it.
I'm starting to think the negative hype on these, as i said, was generated by a) those who read the comments of some who saw a prototype at NAMM before they were released and badmouthed it on line, b) some of the REAL bad tone obssessives (a proportion of TGP) for example, who go nuts for true bypass (when buffers are a good thing) and can hear all sorts of things affecting their "tone" when they can hear a difference that doesn't exist between joyo and freekish blues pedals and c) people who jump on bandwagons and try to sound knowledgeable by regurgitating terms like "over compressed" and "loss of picking dynamics", when they run the gain dimed on their amps anyway.
In the real world? this is a fine tool, absolutely perfect and basically without fault in the event that you want to drop to Eb or D for a couple of songs in a gig, but dont want to bring 2 guitars. or play along to something in the house with a floating trem guitar. It allows you to play most common drop tunings with any config of guitar you want, without the need for a setup. what it doesnt do well is work at the extremes of its ability, but if you want to play the equivalent of drop tuning a low B on a 7 string to A on your 6 string, then buy a 7 string guitar and drop it a whole step, don't buy this and say it doesn't do what it's supposed to. Lets face it, if they had have released the pedal and only had it function to drop a tone and a half because they knew anything past this deteriorated, people would have complained they didn't go expand it's functionality. They did expand it's functionality and people complain because it sounds more artificial the further you go. meh..
It also does an octaver effect, again people complained it sounds artificial. not anymore so than a boss octaver or octavio.. and theyre still good enough for people like Iommi and many others.
Hope this all is informative
« Last Edit: February 27, 2013, 07:35:55 PM by tekbow »
Brow
Re: Arrived: awesome piece of kit, about bloody time..
« Reply #18 on: March 02, 2013, 12:03:17 AM »
That's a great reply Tekbow, very informative.
I pretty much agree with you on every point you made.
Mine came with the USB cable and as I wasn't sure which firmware it had, updated it to 1.2 anyway.
I got mine primarilly as 1 of my bands plays all of our songs in Eb, and I didn't want to limit myself to only using a few guitars so I bought this. I currently have 3 guitars always in Eb, so during our set I'll switch between those and then use the Morpheus so I can use some of my other guitars too.
juansolo
    • Juansolo's Gnomepage
« Reply #19 on: March 02, 2013, 12:12:00 AM »
Not what I was expecting when I clicked on this from the main screen :(
tekbow
« Reply #20 on: March 02, 2013, 12:36:31 AM »
it was cherry..
tekbow
« Reply #21 on: March 02, 2013, 12:42:09 AM »
Cheers Brow, hope you're liking yours and it does what you wanted, im still playing with mine like a kid with a new toy. I'm even starting to like the funky synthy sounding extremes, good for weirdish sounds
tekbow
« Reply #22 on: March 05, 2013, 10:12:13 AM »
Little follow up on this one, had for about a week now and i still think its as good as when i got it, tried it with most of my other pedals and i thought one thing would be worth mentioning. Classic Germanium FF style pedals, it likes em fine, however.. for some reason you lose the ability to back off the volume on the guitar and clean em up that way. at full volume there's no issue, in fact there may even be a little more gain on tap, but i suspect the signal coming from the Droptune is a little hot.. basically when the volume is backed off the fuzz pretty much stays, i have a hybrid Si/Ge pedal kicking round somewhere, will have to see how that behaves
itamar101
« Reply #23 on: March 05, 2013, 12:13:37 PM »
Try putting the droptune after the fuzz in the signal chain, fuzz pedal generally don't like buffered pedals very much.
tekbow
« Reply #24 on: March 05, 2013, 02:17:59 PM »
yep i know, germanium fuzzes generally don't like anything, except for a buffer after a fuzz to change signal impedence, but i'm kind of in delay pedal outwith the loop with amp distortion territory here, do i delay the distortion or distort the delay, generally i always felt delaying the distortion because distorting the delay sounds bad (to me). same with this, do i drop the fuzzed signal or fuzz the dropped signal.. i get the feeling dropping the fuzzes signal isn't going to sound right, and also i have a feeling that this thing is meant to be run straight after the guitar. Maybe a buffer ala fuzz friendly wahs might do the trick.
Its not a big issue, because anything I play in Eb tends to be full on rock out, and at full guitar volume,m it sounds as it should. would just be nice to have the capability for the fuzz to behave a bit more as it should if it was first in line
blue
« Reply #25 on: March 06, 2013, 11:39:26 AM »
I have a Digitech Whammy DT, which does much the same thing as the Morpheus.  i would say all the things you have said about the Morpheus apply equally to the Digitech, except that it adds uptuning and Whammy effects.  the main reason i got it was the droptuning though.  I had been intending to get the same pedal as you until i came across the Whammy.  since Morpheus appears to be AWOL at the moment, i would say this pedal is a very viable alternative.
tekbow
« Reply #26 on: March 06, 2013, 01:00:33 PM »
I heard that full chords dont work so well with the whammy?
blue
« Reply #27 on: March 06, 2013, 01:26:25 PM »
with the older Whammys, no, you got lots of strange warbly artifacts.  which could be a kind of cool effect in itself :)
with this new DT, and i think the new Whammy as well, they have a polyphonic mode, so it handles chords just fine.  the DT is like two or three pedals in one;  on the left is a standard whammy, then the treadle in the middle, then the detune/capo section on the right.
Nadz1lla
    • Arcanum Plectra
« Reply #28 on: March 15, 2013, 12:00:00 PM »
Well, thanks to Tekbow giving me GAS again, I have been following these on Ebay and they keep going higher than you can buy them in stores, so I just ordered one from DV247.
Thanks for that.  -_-
Revenge will be mine!  :lol:
Brow
« Reply #29 on: March 15, 2013, 12:37:25 PM »
That's good news, the band I wanted to use my Morpheus with split up before I even got chance to try it  :lol:
