Author Topic: Schecter Hellraiser with Bare Knuckle pick ups  (Read 10679 times)
Re: Schecter Hellraiser with Bare Knuckle pick ups
« Reply #15 on: March 14, 2013, 10:06:40 AM »
It should definitely be possible to adapt this wiring using the humbuckers in humbucking mode (coils wired in series, e.g. red = hot, black = not, white & green soldered together and taped). Then you could add further switches to coil split or series/parallel the humbuckers.
I have not prototyped this wiring (not even with 3 single coils) so I cannot comment on the results.
Studiostriver
« Reply #16 on: March 14, 2013, 11:56:01 AM »
Ok thanks for your answer.I should then go to "nuts"forum and find that guy if he could lend me some clips to hear how it sounds.
