Author Topic: Jackson Dinky XL Pro  (Read 6389 times)
  • Random Solution
Re: Jackson Dinky XL Pro
« Reply #15 on: April 10, 2013, 04:52:32 PM »
Never tried a Black Hawk and although they seem surprisingly versatile, I suspect they're too surgically tight for my tastes. I have, however, used both a Holydiver and Miracle Man in a Jackson and I wouldn't be without either of them. Both are incredibly warm and smooth; very organic. The Holydiver is more versatile of the two while the Miracle Man is a bit more obviously 'Metal'. I currently have the Holydiver in the bridge of my PRS and there's honestly not much that pickup can't do. The Miracle Man is in the Jackson as it's the more obviously 'Metal' guitar. Trilogy Suites pair well with both and are also surprisingly versatile. Great for shredding and despite being hot, retain a distinctly single coil flavour and can be very versatile. The only reason I sold mine was because I wanted something hotter and with a more 'humbucker' feel.
JCN1218
    • Cabinets of Curiosity
« Reply #16 on: April 10, 2013, 05:03:23 PM »
I have a Miracle Man in my B.C. Rich JRV 7 right now and I love it! Excellent for the style I'm going for and performs fantastically on the low B string. I've been hearing so many great things about the Holy Diver as well, but for some reason my gut is telling me to go with the Black Hawk. Decisions, decisions.
BKPs: BN,Mule,VHII,Nantucket,SM,MM,CS,PK,WP
braintheory
« Reply #17 on: April 10, 2013, 09:51:23 PM »
I have a black hawk in a jackson sl2h and it's not any tighter than the miracle man in my les paul custom 68 reissue.  I also would not describe the miracle man as being warm or smooth.  The MM has sharp, present highs, huge, growly low mids, good, very punchy bass, a little scooped center mids, and scooped upper mids, which makes it have a dark sound even though it has more highs than the aftermath, painkiller, and blackhawk.  The black hawk is a lot smoother and more polished sounding than the miracle man.  The black hawk has a pretty even, neutral voicing (I guess it can be a little bright), and has a full, not harsh sound where ever you play, but I find it a bit too refined for my tastes (for a metal tone I often want some harshness, but not fizziness of course).  The Miracle Man sounds more raw, organic, aggressive/harsh, and to me more ballsy.  The miracle man is awesome, it's not smooth or warm (very much the opposite), and I wouldn't want it to be.  That's what a neck pickup is for IMO.  When I play a power chord with the black hawk it sounds full, very clear and pure, but I always feel like there's no grain or grit, and then I switch over to the miracle man or aftermath and it's all there and a lot more ballsy and aggressive.
« Last Edit: April 10, 2013, 09:56:53 PM by braintheory »
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Mesa/Boogie Mark III Coliseum
Mesa/Boogie Mark IIC+
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
Wizard Modern Classic
  • Random Solution
« Reply #18 on: April 10, 2013, 11:27:40 PM »
Perhaps it depends on the wood but that's how it sounds to me and I don't think I'm unique in that view. When I was looking for an alternative to the Holydiver I contacted Bare Knuckle and said I wanted something that was essentially similar to a Holydiver in being smooth, warm and organic but was a little tighter, a touch more aggressive, more screaming highs and a bit more balls in the bottom end; a bit like a Holydiver +. They came straight back to me and said I'd described a Miracle Man perfectly and in my guitar at least, that's just the way it is. I can only conclude that it behaves very differently in your guitar but I guess sometimes that's the way it is. Before I got the Nailbomb I heard loads of positive things about it that just weren't true in my experience of it. Where it was described as versatile I found it to be anything but that. Where it was described as warm and organic, I found it to be harsh, aggressive and hairy. I wouldn't say that's because other people were wrong, just that it works better in guitars that aren't maple neck-thru. BKP seem to be more sensitive than other pickups to the wood they're in, just as they're very sensitive to height adjustment. All I can say is that I've tried the Holydiver and Miracle Man in the same guitar and while the MM is certainly tighter and more aggressive, it's also very obviously from the same family as the HD because in that guitar at least, it's also quite warm, smooth and organic. Not as much as the HD for sure but it's in the same ballpark. That suits me because both pickups fit in with what I play. The HD covers everything from Blues to 80's Metal and the Miracle Man will run from Classic Rock to more modern Metal while not sounding fundamentally different. Put it this way, in a Rock covers band I could happily play our entire set with either pickup if need be.
