Author Topic: Advice required for my PRS SE Custom 24 - 7 strings  (Read 13606 times)
Re: Advice required for my PRS SE Custom 24 - 7 strings
« Reply #15 on: May 16, 2013, 08:41:48 PM »
Nice! In most axes I still have somewhat of an issue with the blackhawks looks, but in that baby they work!
Now the regular BKP advice is play with your pickup height a bit, they usually are pretty sensitive to that. If you love them now, chances are good they can be even better.
Also I (I suspect I am not alone on this one) would be interrested in any and all additional thoughts on tone, qualities and weaknesses from either early impressions or further down the road.
  • Random Solution
« Reply #16 on: May 16, 2013, 08:56:47 PM »
Yes, it's a great looking guitar and it does seem to suit the Black Hawks. Glad (and relieved) you like them. I'd also like a really detailed review of what they're like. My reviews are usually epic so you don't need to go that far but good quality reviews help us all to learn more.  :D
sulistef
« Reply #17 on: May 19, 2013, 10:44:09 PM »
So, some more days with the pickups, and I if they are really sharp, I have quite a lot of difficulties to find "my sound".
The "organic" side of the pickup is very present when I get on my modern canal on the recto and it sounds like I have "gain over the gain". It's hard to describe and I will try to get some samples (tomorrow because I can not play my recto at 23:38 :-D ). Of course I can get the gain down, but then the sound loses all the power during palm-mutes.
On the other side, the clean sound is sweet and warm ... and for my ears, close from perfect !
I will anyway get an EQ pedal (MXR M 108) and I know it will reduce the "bee effect" from the Hi gain recto chanel, but will it help with my gain on the gain ?
Perhaps is the height of my pickups not good tuned, can it influence these tonality ?
sulistef
« Reply #18 on: May 20, 2013, 11:45:09 AM »
And here are the samples :
the "gain over the gain effect" : https://soundcloud.com/sulistef/gain-over-the-gain
Modern mode : https://soundcloud.com/sulistef/red-modern
Vintage mode : https://soundcloud.com/sulistef/red-modern
My favourite here is the Vintage sound but it sounds already very "grainy" (french translation, I'm not sure it's the correct word :) )
GuitarIv
« Reply #19 on: May 20, 2013, 12:18:58 PM »
Sounds like you have the pickup a bit to close to bridge, that can happen easily especially with Ceramic ones, my Painkiller likes to breathe a bit farther away from the strings than my Holydiver. I would mess with pickup height again, should solve the problem :)
Cheers
sulistef
« Reply #20 on: May 20, 2013, 12:21:43 PM »
Thanks !! Operation screwdriver !! :-)
sulistef
« Reply #21 on: May 20, 2013, 12:45:49 PM »
So I "played" with the pickups height, I have some variations of course but the sound is always approximately the same. I think it's part of the pickup character, or the couple Black Hawk / Dual Recto.
GuitarIv
« Reply #22 on: May 21, 2013, 03:19:00 PM »
Well, BKPs are usually very sensitive to height, so if the sound doesn't change fundamentally it in deed is the character of the Blackhawk.
sulistef
« Reply #23 on: May 21, 2013, 06:55:15 PM »
Yes I think so too. So I contacted BKP for an exchange for Aftermath pickups, these are more conventional but I think it will fit my sound better.
But the blackhawks are really good pickups and I was very impressed by the sound change compared to my stock pickups. And the clean sound was absolutely gorgeous. I think the fizz I have in my sound is due to the high response in the treble band that push the rectifier sound a little bit too much for me. They would be better for my style on an other amp or in lower gain.
I just want to add to the people who adviced me these pickups that I don't regret my first decision because I had the chance to test it on my rig. Unfortunately it was only this "fizz" in the sound that I didn't like but I repeat these are excellent pickups.
I'll keep you informed when I get the Aftermath (black battleworn covered :) )
« Reply #24 on: May 21, 2013, 08:03:07 PM »
I don't think aftermaths will fix whatever is causing that  :?
