Author Topic: What's the best BKP for a PRS SE Torero??  (Read 5225 times)
Re: What's the best BKP for a PRS SE Torero??
« Reply #15 on: June 14, 2013, 12:14:57 AM »
BKP compensates the influence of the cover in the amount of windings, so the differences are small. If you worry about the highs, the alnico NB is warmer en more organic, yet still very tight and agressive. The Miracle Man, according to some users here, is a litte smoother.
« Last Edit: June 14, 2013, 12:17:17 AM by Telerocker »
CaptMurica
« Reply #16 on: June 14, 2013, 12:37:38 AM »
I see... Well, I don't mind the guitar to be a little bright, just not so bright that it gets harsh and ice-picky.
If you do not go after what you want, you'll never have it.  If you do not ask, the answer will always be no.  If you do not step forward, you will always be in the same place.
  • Random Solution
« Reply #17 on: June 14, 2013, 08:18:06 AM »
Out of the Holydiver, Miracle Man, A-Bomb and C-Bomb, it's certainly the C-Bomb that is the brightest but I very much doubt you'll find it excessively so. The A-Bomb I tried was obviously quite a bit warmer than the ceramic version but I can't imagine anything that would be even more tight and aggressive. It was more brutal than any ceramic pickup I've ever tried so I imagine that with a ceramic magnet and more highs it will be even more so. The Miracle Man is smoother, thicker, has a bigger bottom end and in my Jackson, rather sweeter highs than the A-Bomb. While it has to be said that it's less aggressive than the Nailbomb, it's a hell of a long way from being tame. It's certainly a tight and aggressive pickup, it's just that the A-Bomb was so completely OTT I think almost anything would be a bit tamer by comparison. In my Jackson maple neck-thru the Miracle Man is actually more versatile than the A-Bomb was and the Holydiver is in a different world of versatility.
It's a tough one to call this because some of the things you're after seem contradictory. You say you want versatility and decent cleans as well as enough tightness and aggression to do heavier material. That's the Holydiver, without a doubt. Good cleans, the sweetest lead tone of any hot BKP and with an overdrive pedal you can easily go from Classic Rock to Metallica and Children of Bodom. Conversely, you do seem to be strongly drawn towards the Nailbomb. Now that is a pickup with great tone and many redeeming features but in my maple neck-thru, even the alnico version, was the most aggressive and least versatile pickup I think I've ever tried. Everything I tried playing seemed to have '90s Thrash Metal' stamped all over it. It was a great pickup but I wouldn't try it again unless it was mounted in a lot of mahogany or other such heavy wood. My maple neck-thru just couldn't tame it. That leads me to believe that you're prepared to sacrifice some versatility, some of the cleans and some of that sweetness to get something that is a bit tighter and more aggressive. That just has to be the Miracle Man. You may not get all of the qualities of the Holydiver but it would also be giving more than a nod to those qualities you seem to like in the Nailbomb while being a lot more versatile than the Nailbomb, at least in a maple neck-thru. You'll also find that the Miracle Man is the number 1 recommendation for maple neck-thru guitars for a reason. Everything about it seems to fit that construction and configuration perfectly.
Of course, all BKP are great so you can't really get a bad one. If you've not had BKP before, whatever you buy will probably seem fantastic, it's just that in different guitars, some BKP are more fantastic than others  :D
« Reply #18 on: June 14, 2013, 10:21:10 AM »
I can only speak for the BKP's I have, but none of them has a harsh topend. By example, the highs of the VHII in my strat are prominent, but in a pleasant and balanced way, not icepickey.
  • Random Solution
« Reply #19 on: June 14, 2013, 11:01:13 AM »
I think the only BKP I've EVER heard described as 'ice-picky' is the Painkiller and even then, I think it depends on the guitar.
CaptMurica
« Reply #20 on: June 14, 2013, 06:09:16 PM »
I've never owned a BKP so I can't speak for myself. I do trust what you say about the Miracle Man now. I'll look into that and the Cold Sweat for the neck. Thank you for the help guys! I'll let you know what I think about them when they arrive.
