strat with Slowhand + Trilogy
Started by ZECK, June 25, 2013, 11:30:21 PM
ZECK
i have a new AM Std Deluxe and never got used to the N3 noiseless pups.
for my HH strat i put a RY neck & NB bridge and fell in love with BKP pickups so i thought i'd venture into BK single coils for this new strat.
i like the Slowhand mid's ability more than what the IT's produce so my question is would Slowhand's in neck & mid and a Trilogy in bridge be complimentary?
Not quite, referring to the fourth position quack. If that is not important for you, it will be a nice stratset with a more modern sounding bridge and vintageflavoured, yet thicker sounding middle- and neckpickup. Balance should not be a problem. What styles you want to play with it?
Quote from: Telerocker on June 26, 2013, 09:16:16 AM
I agree, since the string movement at the bridge is shallower so a stronger bridge pickup may work well. It is indeed the question whether the #4 position produces a sound that you like. Of course if you don't use that position much it is no issue.
There is a very detailed review on the Trilogy Suite by forum member slartibartfarst42, even though he did not use it in the bridge position of his guitar.
you can go for a set of three slowhands, with a baseplate on the bridge. Very meaty set, I have one :)
BigB
Quote from: gwEm on June 26, 2013, 10:35:50 AM
I've had the SH mid+neck / TS bridge combo and unless you really really want the TS bridge for hi-gain I think you'd be better with gwEm's suggestion, as the SH and TS tones are very different.
ZECK
contemporary blues/rock, starting a fusion class next month,
ZECK
i did entertain the idea of the three-set, though i didn't think of the baseplate. i'm not versed in the baseplate as to what it can offer, sorry to say.
ZECK
Quote from: darkbluemurder on June 26, 2013, 10:15:53 AM
you and telerocker mention the 4th pos. i typically do not use it. N, N+M, B, most often. the wiring setup on this deluxe has the S1 vol switch. not sure how the Slowhands + Trilogy will work with that but my ears are really liking the Slowhands and a bridge Trilogy.
though i will consider more a 3-set Slowhand with that bridgeplate. just not sure that bridgeplate will deliver what my ears are hearing from the Trilogy.
Quote from: ZECK on June 26, 2013, 09:58:23 PM
http://youtu.be/2_lVIWPc38E
If you have not seen it yet this can shed some light on baseplates. Love these BKP tutorials.
Quote from: ZECK on June 26, 2013, 09:56:24 PM
In that case you will be happy three Slowhands, with a baseplate for the bridge.
Btw, I had the S1-switch on my American Series HSS-strat. I had it removed and rewired to a normal five-way switch, with autosplit on het fourth position. I found the S1-system took away some juice, but it could be related to the stockpickups. I didn't try BKP's with the S1-switch.
ZECK
Quote from: Kiichi on June 26, 2013, 10:18:10 PM
well, i'z bez educated, that was enlightening. my ears sure noticed a difference.  thanks for the link
ZECK
Quote from: Telerocker on June 26, 2013, 11:19:00 PM
i noticed  a difference in that video between baseplate and non-baseplate. not sure now of the a Trilogy bridge trumps that, i'll listen to the clips again.
appreciate your insight,
BigB
Quote from: ZECK on June 26, 2013, 10:02:34 PM
The SH and TS are quite different pups and I really doubt a bridgeplate will turn the SH into a TS. Slowhands are beefy single-coils with a hint of a P90 tone (warmer and less scooped than more traditional Strat pups) but still on the vintage side. The TS (bridge at least) definitly has a way more modern voice and vibe (and more output FWIW). I was at first very pleased with this mixed set and the wide array of tones I could get of it, but while I liked both pups I finally found out I would have prefered a more consistent voicing across all three positions.
So, if you're ok with the voicing difference then well, go for it - at worst you'll have a few days to find out if it works for you (if you order them directly from BKP at least).
My 2 cents...
ZECK
Quote from: BigB on June 27, 2013, 08:31:19 PM
My 2 cents...
i haven't purchased yet due mainly to the voicing diff decision. ;-) as you brought up.
did you end up getting a 3-set of SH or TS?
what about a 12.5 Ohm neck TS and use in bridge with a neck&mid TS?
with all the input from this thread and 'my ears' leaning towards 3-set SH with bridgeplate.
ZECK
that was a really insightful helpful review. i was surprized he found they didin't sing chords well.
