anyone ever wound a pickup
Started by monkeywalker, March 06, 2006, 07:28:52 PM
Tim
Wow, brave stuff indeed.I must admit I wouldn't rewind a pickup with it's original wire especially if it's been potted, sure you're going to break up the capacitance but you'll never get it back on tight enough by hand without breaking it as the wax is going to stiffen the wire right up.New winding wire is expensive and very hard to buy in 'small' spools.......the smallest we use is 4 - 5lbs and even then you're looking at over £100 for plain enamel...........solderable polynylon is cheaper but comes on huge 5-6 kg spools usually-enough to make ALOT of pickups but still going to cost several hundred pounds.
A rewind can make an old p/up sound alot better in a number of ways-you can alter the wire gauge, the wire type, the number of turns and the winding pattern.A quicker method than sitting there wrapping a bobbin by hand is to find something to rotate the bobbin for you whilst you feed the wire on between your fingers-you'll have better control over the winding pattern and can control the tension too.People have made winders from all sorts of things-old record players,drills........sewing machines are a favourite.At the end of the day it's whatever suits the person doing the winder-there's no right or wrong so long as you're controlling the wire going onto the bobbin and govern the tension,wind pattern and no. of turns.
Tim
monkeywalker
if i could get hold of some wire i would be willing to pay the price. obviously i'm not exactly good at it but i can't help wanting to try stuff like this out, i really enjoy it and i'm learning new things every time i try something. i have this in controllable need to be doing something with my guitar, if i spent as much time playing them as i do messing about with the wiring and pickups i'd be quite good by now.
i had a feeling the pickup wire would come in very large quantities.
i was gunna email you asking how you get the wind tight enough to fit loads of turns on for pups like the warpig and miracle man, i didn't realise the wax did that to the wire in such an extreme way, it's so fragile, very frustrating to say the least
but yea i'd love to do it from scratch with new wire.
HJM
Warpigs and Miracle men are easier.....thin wire is easier to fit!
VHIIs are trickier - thick wire and lots of turns, if you look at a VHII bobbin they're completely full. Look at a Miracle Man and they look much skinnier!
monkeywalker
Tim do you have a particular wind parttern for each type of pick up you do? if so, does it give greater consistancy in the sound it produces?
while we are on the subject, do you have a favorite combo of pickups or just a fave pup in general?
hobleguitars
I think Tim's said somewhere that the Riff Raff is one of his favourites, but I've never played one to comment on.
Hoble Guitars. Mule + MM so far.
Tim
Mule humbuckers all the way 8) !
Tim
Kilby
Quote from: indysmithI'd really like to wind pickups, actually i emailed Tim asking if i could go hang with him for work experience once, but he said no; the big meanie
Perhaps time should start up a Bareknuckle activitity camp in the summer.
Pickup winding and guitar workshops :)
Rob...
Goodbye London !
HJM
I can see the insurance bill ££££££££
Kilby
Especially if sambo turns up
Goodbye London !
sambo
