Author Topic: Getting into pedals and stuff (finally?)  (Read 15253 times)
Re: Getting into pedals and stuff (finally?)
« Reply #30 on: August 14, 2013, 08:32:49 AM »
On pedals I see what pedals you might need as a matter of taste and style - okay, everyone might want a tubescreamer and a tuner - but what interests me more at the moment are boards and power supplies.
I figure I could probably add a chorus, wah, compressor, and EQ at some point in the future but at the moment all I have is a Decimator G-String II noise gate, a Polytune tuner, a Maxon OD-9 overdrive (basically an Ibanez TS-9 with true bypass), and an EHX Metal Muff.
I need to put the noise gate both before the amp and in the loop, the tuner, overdrive, and muff all go after the gate and before the amp.  I'm thinking of putting an EQ in the loop and a wah before the gate.  I'm not sure where a compressor would go.
Any advice on power supplies and setting up a board with both front end and loop feeding through the one pedal (the ISP)?  I'm in Australia so any power supply will have to be for 240V, and preferably multi-voltage auto-switching
