Author Topic: G&L comanche: slow hand, trilogy, sinner?  (Read 2408 times)
Baby Evil
« on: October 01, 2013, 12:22:10 PM »
I'm looking for a fatter tone from my Comanche.  When I dial in my amps for my hollowbodies with p90's, the Comanche sounds brittle and less loud.
What would bring me in the vicinity of the Nantuckets, or is there a single coil with p90 characteristics?
Jan
SG700S: Abraxas; Haar Tele: Flat 50's; G&L Legacy: Crawler/Slowhands
littleredguitars2
Re: G&L comanche: slow hand, trilogy, sinner?
« Reply #1 on: October 01, 2013, 01:12:59 PM »
well this is straight from the trilogy suite page
Quote
A high output set of single coils with a muscular 'P90-esque' tone deep, resonant bass, wide mid range response and a totally modern voice.
not sure about the slow hands. but the sinners will probably be way too much.
« Reply #2 on: October 01, 2013, 01:52:44 PM »
Trilogies, but they do sound way more modern than the middy Slowhands, which have still that vintage stratvibe.
Baby Evil
« Reply #3 on: October 03, 2013, 07:14:50 PM »
I don't want vintage strat vibe, so I've ordered the Trilogy set.  More on that when they're in the guitar
thanks
Jan
littleredguitars2
« Reply #4 on: October 03, 2013, 08:44:58 PM »
hope you enjoy them! i'll be trying some out soon enough as well!
Baby Evil
« Reply #5 on: October 14, 2013, 06:17:33 PM »
well, they're in.  I definitely hear the P90 reference, and that's a good thing, I don't like strats much.  But the Comanche plays so great, and the sustain is unbelievable, that I'm taking a chance with these pickups.  Also, they work better with my fuzz pedal than all my other guitars.
I do have a lot of hum though, even clean, much more than with my Nantuckets and MQ's.  I ordered a new pickguard, and it isnt shielded.  The ground connections seem ok, could this abscence of the tin foil explain the strong hum?
best
Jan
littleredguitars2
« Reply #6 on: October 15, 2013, 12:24:56 AM »
i'm betting that absence of the shielding definitely plays a factor in your humming. do you have a noise suppressor pedal?
« Reply #7 on: October 15, 2013, 01:23:55 AM »
Probably.  You can get the foil on ebay.  I can't imagine it's hard to apply.
The only thing with it is that you have to make sure that the joins are good (overlapping).  Use a continuity tester (a lot of multimeters have these, but the cheapest ones don't tend to) - it will beep when you have continuity.  An alternative is a couple of coats of the conductive shielding paint on the back of the pickguard.  You can also paint the inside of the guitar with this, or line it with foil (just be careful not to short out the guitar by the hot wires touching the shielding.  Also, if you use the paint wear an appropriate organic solvent safe face mask
Baby Evil
« Reply #8 on: October 19, 2013, 07:46:58 PM »
Havent shielded it because I cut my finger and wasnt able to play this week.  Apart from the crazy hum, the high e string on the bridge pickup is much lower in output than the other strings, and dull.
How's that possible?
Jan
