Author Topic: Need some Les Paul pick up advice  (Read 6095 times)
Rudo79
Re: Need some Les Paul pick up advice
« Reply #15 on: October 07, 2013, 06:03:01 PM »
thanks for the great clips and video's!
I think the rebel yell sounds great, but indeed much too warm for my taste?
Here is an example of my punkish sounding band, you can hear my sound is much cleaner and with much more highs http://stealers.bandcamp.com/track/pretty-city-2# ( this was recorded with my t-top and marshall super lead )..
So now i think i will try the riff raff for the bridge not sure about the neck pick up tho, that's more interesting for the thin lizzy like stuff i also play..
  • Brokeback is back
« Reply #16 on: October 07, 2013, 07:24:00 PM »
I just listened to the track in the link and it sounded super cool. Great punk rock!!!
« Reply #17 on: October 07, 2013, 07:29:30 PM »
I would settle for a calibrated set, but if you're worried the RR-neck is too bright, you might consider a Mule-neck, which is a bit warmer and less bright, but has a lovely crispiness at the same time.
« Reply #18 on: October 07, 2013, 10:18:40 PM »
Listening to the clip it's hard to imagine that you could go wrong with a Riff Raff set.
  • Random Solution
« Reply #19 on: October 07, 2013, 11:23:05 PM »
My first thought was an Emerald in the bridge. Its brightness will work well in a Les Paul and it's quite an open pickup. No doubt in my mind it will do what you're after. For the neck, I'd either go Emerald again or Riff Raff if you want it brighter and punchier.
