Author Topic: Slightly premature NAD  (Read 9855 times)
Re: Slightly premature NAD
« Reply #15 on: October 28, 2013, 01:32:05 PM »
I might see if I can make a cable to actually bypass the whole FX loop too (I'm not a fan of FX loops).
I don't know if the loops on the 5150 are much different from that on my 6534+ - I know the 5150 II loop is the same as mine - but I've found the loop to be extremely useful on mine, mainly for noise reduction purposes with the G-String pedal.  I really haven't found any downsides to the loop on mine, although I know that some amps (such as the Marshall JVM) can have problems with their loops.  I think there may be some effects that have problems in the Peavey loop, but I don't have any in mine.  Most of my pedals - and all of them in the loop besides the ISP - are MXR analogue pedals.  I don't know if they play nice with digital reverbs etc. I'd suggest giving it a try first.  The Peaveys generate a lot of fizz in the preamp section so I found that the noise reduction really needs to go after the preamp.
dvorak
« Reply #16 on: October 28, 2013, 02:05:52 PM »
Nice collection!!
How would you compare the 5150 to the SLO?
PRS Custom 24 - 59/09
PRS Custom 24 SE - Alnico NB/Coldsweat
Vintage V100 Lemon drop - HD
« Reply #17 on: October 29, 2013, 12:43:13 AM »
I used to own a 6505 and I found the preamp generates enough noise to force me to have unnatural settings on my NS2 if I ran it in the loop. I've never used loops and I don't use many effects. My SLO has no loop at all. At most I have a tuner, possibly a wah, maybe a delay, and I run those at the front of the amp and usually on batteries but I do have a good isolated mains supply for them.
Adding a choke will improve the power supply filtering a bit, I'm half way through doing that. I also happen to know from experience which resistors in the preamp can add a LOT of noise. One in particular will be having it's value reduced, which will cut a lot of hiss. The loop being slightly surplus for me, if bypassed, will get rid of 2 valve stages (send and return stage), the associated gain drop/increase in the loop (also boosting noise) and the series resistances in that circuit. I need to check a few things before I try it though but it should just require a jumped wire. The 5150 loop bypass only switches the send and return jack sockets out of circuit. The loop is always passing the signal. There are some more noise reduction tricks too. I'm also careful where I run the gain and I'll be using a 5751 in V1 which should help too.
Compared to the SLO the 5150 is very noisy, has less pushy mids, more fizz, more gain, a poor clean/crunch channel and isn't built as well. BUT... it has that 5150 sound. When I use it I instantly feel like I'm playing with the rig from loads of albums I like... If that makes sense. It's very much a go-to kind of amp for certain styles for a reason. It's based on the SLO100 but it's nowhere near a clone. Just a couple of similarities in the circuit.
GuitarIv
« Reply #18 on: October 29, 2013, 10:22:26 AM »
Just out of curiosity, how did you get into amp modding DMoney?
« Reply #19 on: October 29, 2013, 05:16:36 PM »
I let a mate borrow an old amp at a show and during his bands set a pint of water vibrated off the drum monitor and onto my amp. It blew up. all the power valves shattered. I tried to get an idea of what it would cost to have someone take a look but I had no money. So i decided to learn how to fix it myself. After that a few years of trial and error just trying things out. im very much still learning.
GuitarIv
« Reply #20 on: October 30, 2013, 06:09:06 PM »
Note to myself: borrowing amps might result in increased knowledge about modifying amps  :lol:
I'm just at the beginning of the whole subject, I think once I swapped out Power Amp Tubes and set the Bias myself I'll be feeling less uneducated... if I don't get fried that is  :P
« Reply #21 on: October 30, 2013, 07:21:41 PM »
I will say, I have had some pretty nasty shocks and burns but nothing for a long time now. A mixture of risk taking and messing with amps while being half awake. urgh.
dvorak
« Reply #22 on: October 31, 2013, 01:17:59 PM »
Thanks mate, sounds like it's a nice addition then!
I have always been curious about the variations between the 5150, a Dual Rec and the SLO100. I have always heard very very good things about the SLO100, yet both Peavey and Mesa thought it was worth doing their own variants of them that sound quite different. I own an old Rectifier myself and love it, yet the SLO100 is spurring my GAS.
Toe-Knee
    • DIY Audio
« Reply #23 on: October 31, 2013, 05:37:57 PM »
Everyone needs a SLO or a clone!
It's surprising just how many high gain amplifiers are based on the SLO topology.
http://WWW.BACKLINE.TK
Non Biased Guitar Forum
http://fret.boards.net
GuitarIv
« Reply #24 on: November 01, 2013, 02:55:01 AM »
I swear, one day either I'll get myself a Clone built, build one on my own or buy the real deal  :shock:
