Author Topic: Which Noise Gate / Suppressor for me?  (Read 32429 times)
Alex
Re: Which Noise Gate / Suppressor for me?
« Reply #30 on: October 28, 2013, 08:37:03 AM »
Guys, no need to get heated over this. The Boss and the ISP are different concepts!
The Boss is meant to reduce noise going into the amp, or coming from noisy overdrive/boost pedals, the ISP (and Rocktron Hush Pedal which I mentioned) are more for going into the effects loop (and to cut down amp noise).
« Reply #31 on: October 28, 2013, 08:55:04 AM »
the 3 hush pedals (the first big one with 2 channels, the other blue one and the reaction hush) work pretty well in front of the amp
might try the guitar silencer sometime just to put the pedals in the silencer loop, but the reaction works really well for me at the end of the chain
I paid US$55 for the reaction (new from a store) and US$28 for a used 2 channel blue hush pedal
hard to beat that sort of cost benefit
those are very sturdy and effective pedals
recently got a new noise clamp for cheap and it was disappointing
and it also came wth a defective switch, like the mxr wylde
even the behringer noise reducer I had was more useful
« Last Edit: October 28, 2013, 08:57:34 AM by Eric Hellstyle »
EffigyForgotten
« Reply #32 on: October 28, 2013, 09:20:09 AM »
I've tried all three, and would forget the Boss in this day and age.
Actually the vast majority of pros are still using ns2's in this day and age......... mastodon, metallica, killswitch engage, machine head, steely dan, dillinger excapeplan, slipknot, periphery, symphony x the list is huge and its still the most popular noise gate amongst the pro's.  Tone is subjective but I dont think noise gates are so ill go along with the pro's sure a few use ISP but who even uses the mxr noise gates??
I've had the ISP and the NS2 and MAYBE the ISP is ever so slightly better but for the money it really isnt worth it. Were talking about the smallest amount of noise reduction and does it matter when youre playing guitar any way?  For pedal hum and a hi gain there may be a little noise but turn your volume down too and its gone and youve saved your self some money!
The things isin fairness I get you only need some thing in the front of your amp which saves on cost but if anyone wanted a noise gate for the input / fx loop the boss ns2 is £69 new (Cheaper 2nd hand I got mine for £30) and the isp decimiator g string ii is an extra £100 which is just robbery imo !!!
That being said if money isnt an issue go with the isp
I'm sorry but do you actually believe Killswitch Engage and Slipknot are PROS? I laughed way too hard than I should of at this..
« Reply #33 on: October 28, 2013, 10:28:17 AM »
I thought that with the boss unit you create a 'loop' in the front end of the amp.  For example, you could run the distortion pedals through this 'loop' and then go from there into the modulation effects.
Like this (loving the socks & sandals look!):
http://www.youtube.com/watch?v=zV76RdTiIUA
« Last Edit: October 28, 2013, 10:32:56 AM by Agent Orange »
JimmyMoorby
« Reply #34 on: October 28, 2013, 11:16:24 AM »
Im not getting heated mate I just think I was just misunderstood. I just wanted to make the point that the NS2 isnt 'redundant' before any thing else.  By definition it cant be if so many pro's still use it which one is better is down to the individual but I think its misinformation to say some thing is useless and the music industry has moved on when its used to good effect by so many people.
Oh and KSE and Slipknot are pro's whether you like them or not doesntmatter im not a superfan of either but ill trust bands who play massive festivals and gigs which knowledgable techs to pick the right noise gate (And yes ISP fits in there too and as ive said is a tiny bit better)
« Last Edit: October 28, 2013, 11:24:10 AM by JimmyMoorby »
GuitarIv
« Reply #35 on: October 28, 2013, 11:27:31 AM »
No problems whatsoever with my NS-2. I had the same issue once and I really wanted to get myself the ISP. Then I tried it out and realized I really like the coloration of the sound the Boss gives me, the ISP is very transparent and doesn't change your signal in any way. Turns out the NS-2 does something tonewise I really like.  :D
Toe-Knee
    • DIY Audio
« Reply #36 on: October 28, 2013, 04:57:36 PM »
I imagine they're a lot more professional than you are.
http://WWW.BACKLINE.TK
Non Biased Guitar Forum
http://fret.boards.net
Toe-Knee
    • DIY Audio
« Reply #37 on: October 28, 2013, 04:58:56 PM »
The NS2 boosts the signal and rolls off the high end a touch. It can be used to your advantage. However it can be a nightmare if you try to use it with a loop that's +4dB
« Reply #38 on: October 28, 2013, 05:36:32 PM »
Ok guys, thanks for the lively discussion and the insight. For now I have settled with an ISP Decimator clone from our dear Juansolo. Works out to cost me less than a new NS-2, so that seems to be cool.
Reading all of this I would however still like to learn more about the NS-2 and Smartgate (and Hush for that matter) and try them at some point. It really is an interresting topic.
Oh and say about guys like Adam D. and Jim Root what you will, but they are great players and surely are pros (especially Adam D. I mean he also is a producer who graduated from Berkley...not too bad in my book).
« Reply #39 on: October 28, 2013, 06:52:45 PM »
I'm guessing they use the boss because they're easy to get hold of. If I were in a world touring band I'd use what I could get hold of easily, too, just in case everything decided to die.
I agree that the g-string is very expensive. Kiichi said his amp doesn't have a loop, though, so he only needs the bog standard decimator, which is a lot less. Also, as I said, I had limited (read: no) success with trying to cut anything other than pedal noise with the ns2 if I couldn't use the x-pattern (which you need an fx loop for). Those pro guitarists' amps probably have fx loops. If your amp has a loop, I'd agree that while the boss probably isn't quite as good as the decimator, the decimator is an awful lot more expensive for slight improvements.
you can use the ns2 in the loop if you use the x-pattern method, though
FWIW I agree it's not redundant (and I like KSE :lol: ). I do prefer the ISP, though- like Toe-Knee says, the Boss isn't that transparent. I wouldn't say the ISP is totally transparent, either, but it's a lot more so. Now, of course, some people (like GuitarIv) might like what the Boss does to their tone, and that's their prerogative.
CommonCourtesy
  • King of da Chug
« Reply #40 on: November 02, 2013, 08:37:25 PM »
I can relate to the NS-2 sucking tone, i don't use it anymore but since i'm hoping to upgrade my amp to a high gain one i will have to reintroduce it into my board i think!
Have read alot of good things about the ISP (G string one) esp if its just for controlling noise coming from the pre-amp and not noisy pedals. I'll most likely get one cos the only pedal i use in front of the amp is a tubescreamer.
Haven't tried the MXR to comment, sadly.
