Mule or Riff Raff for my Bacchus Les Paul
Started by Marco78, November 03, 2013, 09:26:54 AM
I'm wondering if the Emerald set might be worth considering?  It has a vintage flavour, and should be good for those leads, but it might be too hot for you.  The main issue with going hotter is that it can overdrive the tubes a bit and warm up the sound, but if your amp can take it then it won't matter.  It's only with more gainy amps that this seems to be a real issue.  The other issue that people have with hotter pickups is them being dark, but the Emeralds seem to be bright, and would balance well in a darkish Les Paul.  It also seems to have quite a bit of PAF character.  Doesn't seem to me that it is a typical hot pickup.
Marco78
#16
On this forum I saw a video of russian boy with Gibson Flying V with Mule/RR combo. Can someone link this video?
Agent Orange I'd get a real PAF pickups. Emerald are probably a different pickups...
One of the great things about having a Les Paul with regard to BKPs is that its easy to find clips of each humbucker in a Les Paul - all of the sample clips on the BKP site were recorded in one. This means that it is much easier to trust your ears as to which one one you like best.
Marco78
Yes, but on rock samples are used almost only bridge pickups.
