Quote from: Lucas on December 17, 2013, 10:51:55 PM
Quote from: Kiichi on December 17, 2013, 10:41:45 PM
Pleasure! Spreading the good word. ;)
Having written it out like that may tempt me to copy and paste at future occasions.
Make sure to do it, it solves all mysteries and confusions! Great job indeed.
So basically if I want to split both pups I have to apply that diagram to both of them following the same principle? Resistors on both paths?
And what kind of resistors would you recommend, I mean quality-wise. I suppose they are not that expensive so I would want to go with the best quality ones.
cheers.
Yes, resistors on both paths. That is because you generally want different values for neck and bridge. The bridge can do with more bottom end, thus the higher value, which results in the coil stayin on more.
To elaborate slightly further on the concept of this (sorry if I am overdoing it here):
You see the wire pair coming from each of the PUs in that diagram and how they lead to the side of that push pull pot. Now this shows how the push pull function operates
http://www.smitspickups.com/coilta18.gifWhen you now follow the path of the signal in you head you can see that when the pot is in the signal has nowhere to go, so it is just like they are taped off at the side you like they would be for normal operation. When the pot is pulled they are send to ground (notice that where that bridge is there is a ground connection).
The goal is now to place a resistor somewhere between the wire pairs and the ground to keep some of the signal from disappearing there. You could just put one between that bridge and the ground, as signal from both PUs goes through there, but then the same value would be applied to both, which for the reasons stated above you do not want. One resistor for each PU between wire and pot and you are set.
Resistors are really, really cheap and there are hardly any quality things to look for. When we look at potis (variable resistors) we can look for things like taper, build quality, sturdiness, how smooth they rotate, size, tolerance, etc. With resistors most of those are not of importance. Here we mostly concern our selfs with how much current they can take and tolerance. In this case the current is super low, so now worries there. Since it is a static thing there really is not much to look out for except tolerance. This is expressed in % and tells you how far off the stated value this resistor can be. The closer, as always, the better, but not even that matters much in this application.
Resistors are pretty clean parts and have such low tolerance that it is hard to go wrong. Of all the usual building parts, these are the least mojo of all.
A german online shop Juansolo once recommended to me sells ones with 0,6w rating, 1% tolerance, metalfilm style for 6 cents a piece. I use those for pedal building and all things and they just work.
Really, just get some and if you have the choice go for low tolerance.
