Author Topic: 4way switch wiring  (Read 16640 times)
Shadowvault
Re: 4way switch wiring
« Reply #15 on: December 31, 2013, 01:21:04 PM »
I think i will do it this way.I dont wanna experiment so much the first time with the wiring so i'll keep it like that.You dont have to hurry up.I will order the parts today so...
Why do you suggest push/push?What do you mean its more easy?I am asking because ive never seen one
Skilpad
  • Riff Raff N, Cold Sweat B, on ESP Eclipse II
« Reply #16 on: December 31, 2013, 02:16:58 PM »
With push/push, you just push each time you want to switch position. I find it is easier and faster than grabbing and pulling when you want to activate. Moreover, it is easy to push to buttons at the same time... It is harder when you need to pull them.
Some people prefere push/pull because when pushing or pulling, they are sure to get the position they want (while with push/push, since you switch position, if you are mistaking the initial condition, you will go to the wrong position). However, you usually actually know yet in which position you are, and you can still have a look.
It is a matter of choice, but push/push are faster, you do not care about slippery knobs, and you will never tear the knob away while just trying to split coils.
By the way, I got Tim's answer: the 4-way toggle from BKP are the "good ones". So you can take one without hesitation, to put HB in series or invert phase. (Plus: at this point, two additional wires for the 4-way toggle will not change a lot, even if it is your first wiring. ^^)
By the time you get your order at home, I will have done the different wiring diagram. So no need to choose now what you will do with your material. ;)
Shadowvault
« Reply #17 on: December 31, 2013, 02:25:18 PM »
Really cool!I will to with push/push then.Do you know if i have to buy extra wires or i will have everything included with the materials?If so were can i get some?Thanks a lot :D
Skilpad
« Reply #18 on: December 31, 2013, 03:09:18 PM »
There is no extra wire, or any soldering material.
You can use standard wires (thin wires for electronics... not big thick wires for home electricity of course). So you shall find it with the soldering material (or if you ask to someone else to do it, he shall have some wires).
« Last Edit: December 31, 2013, 03:48:17 PM by Skilpad »
