Author Topic: Gonna get me a '58 two-tone GA-40  (Read 11535 times)
sambo
« Reply #15 on: March 21, 2006, 11:20:01 PM »
looks blooming nice!!!!
Tinus
« Reply #16 on: March 21, 2006, 11:21:21 PM »
Quote from: The amazing Phil
I've always been tempted to splash out on a vintage amp myself, these pictures are bad for one's GAS don't ya know old boy.
Sure I do, I just like teasing  :orcass:
Buying these things is quite a leap in the dark 'though, I found it hard assessing this amp at the seller's house because he hadn't run it in 5years or so and it needed some time to wake up again. However I'm glad I did, even now the sound is already way better than most current production amps of similar wattage and price (apart from some boutique combos maybe).
The reason I picked up up this one is that I like the power (14W) and speaker (Jensen P12R alnico) which makes for a nice home/recording/small stage amp. Also these were well built, better than most competitors and on par with it's direct competitor from Fender (Tweed Deluxe). The tweed Fenders of the same era have rather insane vintage value these days.
sambo
« Reply #17 on: March 21, 2006, 11:25:26 PM »
my fingers are tired... i cant be bothered to check if you already said the price on the last page... how much you pay for it?
Tinus
« Reply #18 on: March 22, 2006, 12:32:14 AM »
Straight swap for my mid nineties Rickenbacker 330-12, so about €1000 in real life. That's not especially cheap if you compare it to prices in the USA but shipping, taxes and customs add a lot apart from the risk of damage. Also, this one hasn't been messed up by previous owners and still has it's orignal speaker in good shape so that adds a bit to the cost too.
sambo
« Reply #19 on: March 22, 2006, 07:42:22 AM »
cool thats a fair deal i spose, although i dont know much about the value of either items really.
Underground_Player
« Reply #20 on: March 22, 2006, 12:19:52 PM »
Quote
The onset of overdrive is very gradual, at first the sound only thickens up before breaking.
So you mean there's a point where you can't tell whether it's clean or just really smoothly overdriven? That's the Holy Grail!!
I wonder if that characteristic has anything to do with the teeny transformer PDT_049
Mostly Harmless
Kilby
« Reply #21 on: March 22, 2006, 01:57:20 PM »
can't wait to hear a clip of your new acquisition.
I love small amps, though in my case even 15 watts is too much :(
Rob...
Goodbye London !
Tinus
« Reply #22 on: March 23, 2006, 12:01:25 AM »
Quote from: Underground_Player
Quote
That, and the lazy 5Y3 rectifier, the small power section, low power Jensen (rated only 12W), low preamp gain / no master volume, and ..... ow shoot, the whole thing combined I guess :D
Tinus
« Reply #23 on: March 23, 2006, 12:10:07 AM »
Quote from: Kilby
Rob...
In one week I'm gonna rehearse it (small band setup w/o drums) and I'll have access to a PXR-4 minirecorder so I'll try and record some then.
I doubt if this one would be too loud for you. It saturates pretty early (around 4) and only gets really loud past 8 or so. However it sounds thicker and larger than any amp of this size I ever heard and it's not even repaired yet :D.
Tinus
« Reply #24 on: March 23, 2006, 12:13:26 AM »
Quote from: tewboss
I know that Tube Amp Doctor sells unusual valves, so check out their site.
FYI I checked their site again and found out they Do actually carry 6SQ7's and 5879's so I could use them to order valves too. I forgot to check the odd-ball tube section, silly me....  :oops:
Tinus
« Reply #25 on: March 23, 2006, 02:15:15 PM »
In the mean time I sent some pics of the inside to a tech and made an appointment for a cap job and general maintenance for april 9th. I'll be present to watch and learn and will take some pics. I'll keep you all posted on the resurrection of this nice little ampie.
Tinus
« Reply #26 on: April 09, 2006, 11:48:32 PM »
Well, the GA20 was serviced and restored today with excellent results. I had an excellent day because I got to watch every move and do some small chores to keep the process going.
Some basic stuff was done first. The awkward thin power cord was replaced with a modern one and the chassis is now connected to earth. I got a new external 220-110V transformer that could power three of these amps on full tilt so it's running nice and cool. The inside of the back panel was covered with metal foil for screening, which helped to reduce noise. The valve sockets were cleaned. Some were filled with an earwax-like substance that had leak out of the busted main filter caps.
The tech then measured almost every seperate part to assess if it still performed somewhere near the specs as in the circuit drawing. Apart from replacing the main filter caps all other electrolytic caps were replaced too, as well as some carbon resistors that had drifted too much. Funnily enough it turned out that there was a dead resistor just in front of the driver valve so the amp was running only at half power all the time  8) For nostalgic reasons we cleaned up and refitted a strange sand resistor in the power stage that is common to Gibson amps. (I first thought it was rotting or something but I found out they were supposed to look like that). We left the tremolo alone for now. It doesn't work properly yet but repacing the 6SQ7 might fix it so I'll try that sometime soon.
I'm not gonna ramble alot about the sound but boy.... The nasty noise and hum is gone, the amp is literally twice as loud as before and it sounds much livelier. It will easily handle bar and medium sized venue gigs, it's incredibly loud for it's demure size. The single tone control works nicely. From very dark to normal on the first half of it's travel, from there the sound loosens up and the volume increases. With my BKP Casino and Banzai booster it's instant Neil Young now. Will try and post pics and a soundclip soon.
