Are CTS Pots that hard to turn? What about Burns Pots?
Started by NateCordova, January 17, 2014, 09:17:41 PM
Lucas
Obviously I was as gentle as I could and was enlarging the hole by touching the sides being careful to keep it even. At the beginning I was worried about the finish if it`s gonna come off or something but no, everything was fine, and the job was done within minutes.
It might be little drastic method but thankfully worked no problem.
Quote from: Lucas on January 21, 2014, 12:10:09 AM
The only issue I had was right at the start when I was still doing it with my fingers and a lump in the paint snagged the drum and chipped off.  You can see the chip in the photo below.  It also shows how I basically just took off the paint and then the holes were big enough
Lucas
But those tiny chips will be easily covered by pot`s washer as well as knob itself, so I wouldn`t be worried too much. I guess it depends on the type of the finish and paint used, one might snap off more easily than the other.
Quote from: Lucas on January 21, 2014, 10:10:43 AM
Yeah that little chip hasn't been a problem at all. The only thing I worry about is cracking the polyurethane, as it can then come off in a big piece.  But it just came off as a tiny chip on that middle hole
