Yes good quality pots and caps do make a difference. Insures you get the results that your pickups were designed to sound like. Also a good quality solder job is important as well !! Over heating can damage and sometimes ruin the components. I gutted my whole guitar and redid everything, even pulled the tailstock stud and replaced the ground wire. Id even go as far as suggesting replacing the factory stuff, which most of the time is garbage, before swapping pickups. This will give you a baseline on what you have and how to approach a new pickup purchase tho we all want them new pups regardless :lol:
I wouldn't say a overhaul on the wiring kit produces dramatic results but it lends clearer definition and improves the guitar-amp response relationship.
