Author Topic: NPD - Maxon OD820 clone  (Read 7841 times)
« on: September 09, 2014, 12:12:40 PM »
Just arrived through eBay. No idea how it will be at this stage, but it's nicely made and I have good hopes.
Plenum n Heather
Re: NPD - Maxon OD820 clone
« Reply #1 on: September 09, 2014, 04:41:04 PM »
If it's anything like the original, it will kick butt!!
« Reply #2 on: September 09, 2014, 04:44:54 PM »
Yeah, heres hoping! I have one of Juan Solo's Klons, though it is quite big. I was half thinking to get one of his small ones, but in the end decided to try something a bit different.
heres a gut shot from the ebay ad:
looks tidy. we'll see!
Brow
« Reply #3 on: September 09, 2014, 05:06:12 PM »
I've never tried an 820 but am curious. I think Tony has an 820 Clone, so hopefully I'll try it at the weekend.
« Reply #4 on: September 09, 2014, 06:47:27 PM »
I really like the OD820. It's not exactly my Emma Reezafratzitz, but more or less in the same ballpark.
juansolo
    • Juansolo's Gnomepage
« Reply #5 on: September 10, 2014, 08:19:45 AM »
Similar principle (op-amp OD with a clean/dirty blend) as a Klon. REALLY good OD.
The only other one I can think of is a Kingslayer, which is my personal favourite of the three.
« Reply #6 on: September 10, 2014, 09:02:10 AM »
tried this morning, sadly this one has issues :( i'll get in touch with the builder. its rather dark, and the volume control is more like a fuzz control
update: builder happy for me to return it back for a fix, which is all as it should be
« Last Edit: September 10, 2014, 10:03:02 AM by gwEm »
« Reply #7 on: September 14, 2014, 09:36:40 PM »
All very strange. Builder could find no problem with the pedal so I the same set up with my Klone. Exactly the same fuzz tone, I wonder if it is because of the low end of the Aftermaths in the test guitar.
« Reply #8 on: September 17, 2014, 04:46:36 PM »
got the pedal back, builder was very helpful in fact.
the tone pot is changed so it gives a much more usable sweep.
the volume control still gives a fuzzy tone with certain guitars. by far the worst is my hamer with aftermaths, but some others do it a touch too.
i feel sure this is because of bass frequencies on the pedal input.
as i say, the problem also affects my klon, but not my sd-1 or od-1
i wonder if it would make sense to include an input parametric shelf filter on high end pedals to adjust low-end cut <- answers on a postcard.
generally i have found with clean boosts that the boost only works so far and then things fall apart unless you do some frequency tweaking. thats why i like to use EQ pedals as a clean boost.
overall, klon vs od820, i have to say i like them both alot. the drive seems to sound a bit different. i know people say the 820 is better than the klon, but i couldn't honestly agree with that. both are excellent, i'm pleased i have both.
« Last Edit: September 17, 2014, 04:50:56 PM by gwEm »
Plenum n Heather
« Reply #9 on: September 17, 2014, 09:17:21 PM »
I wouldn't say the 820 is "better" than the Klon; I certainly prefer it because it has more gain on tap; but at the lower end of the range, they are almost identical. I did a shootout a while back that compared a (real) Centaur w an OD820. You can hear the 820 get really gain-tastic at the end.
« Reply #10 on: September 18, 2014, 02:34:28 PM »
An excellent description
