Author Topic: NPD: TC Electronics PolyTune Mini  (Read 5539 times)
« on: September 27, 2014, 02:55:52 PM »
A friend of mine contacted me on Facebook to ask what kind of power supply I use on my board, as he had recently purchased a pedal that did not take batteries.  He was quite shocked when I told him that I use a T-Rex Fuel Tank Chameleon and he saw the price, as I think he was thinking of something around $30! You can't even get a One Spot for that here!
Anyway I was asking him about the pedal and he sends me a photo, and I see that it was a PolyTune Mini.  I then mentioned that I have a regular PolyTune, and when he found out that it uses batteries he decided he wanted to swap, knowing that I could use the space on that end of my pedalboard.  Anyway to cut a long story short we exchanged pedals yesterday and I tested it out tonight.
Like the other one it works a treat, and I had no problems tuning my bass with it tonight in exactly the same way I tuned it with the other pedal, i.e., using the chromatic mode while leaving the tuner in guitar mode and D standard polyphonic mode.  Here though are a list of the features on the standard model that have been sacrificed to make a smaller unit.
1) No Display button.  This means that there is no switching between 'needle' and that other horrible display for chromatic tuning (it's needle only, which suits me), and no bass mode for polyphonic display (I never bothered to use that anyway, I always leave it in guitar mode and D standard for my guitars in the band; I might however buy a regular unit if I ever build a separate effects board for bass only).  So basically the two display modes are needle chromatic and six-string guitar polyphonic.
2) There is no USB port.  This means that you can't upgrade the firmware using a USB cable.  I never did this on the old unit and I don't know when I would have, although it might have been good if people had really early versions and wanted to upgrade the firmware for the drop tuning mode (the drop mode is included with the mini, btw).
3) There is no 9V out.  This is the only one that affected me, as I relied on that, but for the moment I've removed one pedal (the MXR M-80 DI box for bass) from my board until a new daisy chain arrives from China.
4) There is no facility for changing the pitch, which is set at A440Hz.  I have no idea why you would change it.  Perhaps I am a philistine but I expect that few people are going to miss that feature.
So, no real loss for me except for the size of the unit.
Here are a couple of before and after photos showing the size difference.  The smaller pedal gives me more room so that I can access the boost switch on the right side of my wah pedal with my toe.
« Last Edit: September 27, 2014, 03:06:14 PM by Agent Orange »
CommonCourtesy
  • King of da Chug
Re: NPD: TC Electronics PolyTune Mini
« Reply #1 on: September 27, 2014, 05:25:31 PM »
I got one of those about 2 months ago, I was playing a gig in a place where all the equipment that ran off a mains HAD to be PAT tested, and my board hadn't been since 2011. So I ordered it thinking it would take a 9v, only to find when it was despatched it doesn't! The compact size is pretty cool though I could fit it in my pocket. I usually use a Diago Micropower or for my main band board a T-rex Fuel Tank Junior so no need to power off it.
The annoying part is I didn't need to use it for the gig as I got away with using my 'full' board anyway! Now I just use it for rehearsals in a 'mini' board, involving an NS-2 and a Triple Wreck Pedal.
« Reply #2 on: September 28, 2014, 03:12:59 AM »
I see you're are a MXR-fan.  :wink: You also have quite some noisesuppressing going on there.
« Reply #3 on: September 28, 2014, 02:13:26 PM »
Yes, many MXR pedals ... with the steel framed Pedaltrain, T-Rex power supply, and all those heavy MXR pedals this board weighs a ton!
The noise suppressors are there for the Stockholm P-90 SG Junior running through a Peavey 6534+ ...
The Boss NS-2 isn't actually used that much unless I am getting a lot of 60 cycle hum from the environment or I have the 6-band EQ or compressor engaged.  The only pedal before the NS-2 are the Polytune and the guitar in/out of the ISP.  Pedals in the NS-2's loop are the Crybaby From Hell, Custom Comp, Custom Badass Modified O.D., and 6-band EQ.  Then the signal goes through the Phase 90 to the amp input.  The ISP pedal is after the 10-band EQ in the loop and then it goes through the flanger, chorus, delay, and boost pedals back to the loop return.  If I use my Morley volume pedal that goes between the guitar and the tuner.
« Reply #4 on: September 28, 2014, 03:07:10 PM »
Nice board there mate. Interesting review, this is certainly a pedal I'd consider.
