Author Topic: crawler bridge and bonamassa neck  (Read 12871 times)
peter
Re: crawler bridge and bonamassa neck
« Reply #30 on: November 07, 2014, 07:16:52 PM »
got my mule neck today smooth as silk really something else and volume much more volume than seymour duncan its like yeah this guitar has power hehe even when its called vintage :)
BKPs: crawlers hsp90bluenotes abomb cold sweat
« Reply #31 on: November 07, 2014, 08:42:28 PM »
Yeah, the Mule-neck is fab, one of my favorites. Did you manage to balance the Crawler and the Mule-neck?
peter
« Reply #32 on: November 07, 2014, 08:44:40 PM »
yep and i tryed them on a old jcm 900 and the mule is sick on lead channel best overdrive sound ever  :)
« Reply #33 on: November 07, 2014, 08:47:00 PM »
Great! Have fun with this fab combo. :-)))
peter
« Reply #34 on: November 07, 2014, 08:49:06 PM »
peter
« Reply #35 on: November 07, 2014, 09:18:37 PM »
im not sure about the crawler bridge after playing i thoguht it was a good combo but then later thinking and visualising the sounds mule is my tone while crawler isnt really it has a kind of metal voicing on cranked dark bassy metal something and ive had it for a while its a good pickup but the mule is better for my kind of playing  so im thinking about bridge what to do order a mule bridge to go with the mule neck or something voiced like the mule but able to play any  genre exept metal there is and what is the name of that pickup? if there is one a mule but more power for screaming leads  :)
« Reply #36 on: November 08, 2014, 01:28:07 AM »
Come on, the Crawler is not a metal thing, it's more or less a hotrodded Mule. Maybe you should lower it a bit and use a bit less gain.
peter
« Reply #37 on: November 08, 2014, 01:35:18 AM »
il think it over worst thing that can happen is i get a mule bridge and i have a mule set :)
« Reply #38 on: November 08, 2014, 05:18:29 AM »
Mule-bridge is quite bright compared to the Crawler.
peter
« Reply #39 on: November 08, 2014, 06:25:52 PM »
ok i adjusted hight and its better now more the same level of volume and on middle they blend  better i remember it being the same thing with other pickup manufacturers you need to tweak with hight on pickups and amp to get it right when you get it right its all good :)
« Reply #40 on: November 08, 2014, 06:41:09 PM »
With scatterwound pickups every mm changes the spectrum.
peter
« Reply #41 on: November 09, 2014, 05:51:14 PM »
i have them  corected now they are both good on clean as well as overdrive so no more tweaking it is as you said every mm counts :)
« Reply #42 on: November 09, 2014, 11:26:29 PM »
Thumbs up!  :smiley:
