Crawler vs Nailbomb vs Holydiver for PRS Custom 24
Started by skeeter, December 27, 2014, 05:29:20 AM
Duck2587
You can't tell the difference. It's more cosmetic.
Amp-EVH 5150 III 50 watt, 2x12 cab with V30's, Creamback M and Hellatone 30, EP booster through FX loop
Guitars-McNaught, Vigier
Picks-Bronze, Stainless, Brass, Hufschmid
skeeter
Quote from: darkbluemurder on January 15, 2015, 12:56:27 PM
Most of the time it does not make a sonic difference but an optical one. Best move is to measure the string spacing.
Generally when in doubt (with emphasis on the last three words - best to clarify beforehand) I would
- choose the 53mm string spacing (better too wide than too narrow)
- choose short leg (in 95% of all cases it will fit into guitars that had long legged pickups) and
- choose 4 conductor wire (it's easier to ignore the separate set of wires than to change the wire on an existing pickup).
Thanks, I finally placed my order and did just this - 53mm for the Crawler bridge.  And the Emerald neck.  Both short leg, 4 conductor, in reverse zebra (black outside, creme inside)
Ben at BKP made sure everything was correct, including the magnet flip for the PRS 5-way.  Now the waiting game begins!
I'll be happy to post a tone report and some clips once I get them installed  :grin:
Duck2587
Great, hope they will go beyond your expectations. Fiddle with the height to find the sweet spot. Scatterwound pickups are sensitive beasts.
That's a great combination and one I used myself for a while. The Crawler is probably the best Bare Knuckle pickup I ever owned and was absolutely perfect in my PRS. The Emerald matches well in the neck, though I eventually switched to using a Holydiver in the neck as it had the more vintage tone I was looking for there.
keen007
I have 59/09s which sustain forever but are a little too hot for my blood. Looking to swap for 57/08s. Happy to trade.
Quote from: Slartibartfarst42 on January 18, 2015, 09:40:26 AM
Or a Mule-neck  :wink:
skeeter
This is a long overdue post.  I just wanted to sincerely thank everyone for their insight.
I ended up with a Crawler bridge/Emerald neck in my PRS Custom 24.  And it has worked out perfectly! Even after 6 months I'm still impressed with the range and sound of these pickups.
The Crawler is a real rock beast.  It has a very distinctive throaty roar to it - loving it through my old Bogner and my recently acquired Friedman.  It is really thick and definitely beefed up a thin sounding Cu 24.
The splits are fantastic too - they remain full and lush, almost like a Telecaster on position 4 and sorta Stratty/p-90 in position 2.  I don't know if it's the Alnico IV magnets in the Emeralds, but they definitely have a gorgeous sound.  Both humbuckers together balance really well, taming the Crawler a bit and making the middle position very usable for clean arpeggio work.  This p/u combo produces usable tones in all 5 positions - great fit for anyone with a PRS w/5 way.
Last, the Emerald on its own is a great combo of modern and vintage.  It cleans up well and definitely has a warm blues tone in there as you add gain and responds well to picking dynamics.  But cranking with more modern gain they really cut through with a liquid tone that works for Petrucci/Vai or fusion - while tracking with clarity and remaining extremely articulate.
Anyways, I just wanted to finally get around to thanking everyone here, as they helped me make the right choice.  These pickups have definitely been the best upgrade I've ever made to a guitar.
And now, I have a few other projects floating around in my head and some other BKP's in mind to try out... :evil:
Glad to hear it worked out exactly like we hoped. Good to hear that we have another convert. =)
Quote from: Kiichi on September 30, 2015, 02:32:47 PM
Amen!
