HSS set for mahogany Parker Nitefly/MIDIFly
Started by Piplodocus, February 03, 2015, 12:30:16 PM
Piplodocus
Hmmm... I don't know what I want. That's the whole problem. I guess I want something a little different to the HD in my Mojo, so maybe that is it.
I'm working in the principle this other Swamp Ash Nitefly I might go Crawler/MM for a more hot rodded humbucker + the more vintage SCs, then make this one a bit more bitchin' with a harder sound than I originally was planning and the hotter equivalent of the Mothers Milks (ITs).
Then I get:
Big and Fat - Mojo Fly with HD/Mule (mahogany thru neck)
More grungy/punky/snarly/contemporary heavy - mahogany bolt-on MIDI Fly w A-Bomb and Irish Tours
Funk Rock fusion - swamp ash bolt-on Nitefly with Crawler or something + Mothers milks.
(and super-twang - tele with vintage flavour Seymours, at least for any foreseeable future after I've bought these + another set later for the Nitefly SA)
Then it kinda makes more of a spread in the long term master plan. There's a video of a newer different design Nitefly with an A-bomb going through a Peters on YouTube. Might go look at that again.
At least if I buy some, for some and change my mind it's a lot easier than my HD/Mule where I had to cut the legs off to fit them. Obviously wouldn't be able to sell/return those! Good job I like them! :)
Fly Mojo: HD/Mule | MIDIFly (Nitefly M): Abomb/Irish/Irish | Nitefly M: Abomb/Supermassive/MMilk | Nitefly SA: Crawler/MMilk/MMilk | Southern Nitefly: Blackguard set
Piplodocus
Can you gimme a brief description of that Suhr diagram and what it's doing Telerocker? I could sit and try to work it out but I already have a headache from trying to follow all my hex piezo wiring and custom switching mess for the MIDI pickup and acoustic sounds round this guitar this evening. Just a brief description of the principle will do great. Is that a single 5-way quad pole selector switch or something, my brain's not working today, but it seems to have a lot more tabs than mine unless it's 2 switches?  :undecided:
It puts 250k volume and tone on the singles (including the M+split bridge setting), 500k volume and tone on the humbucker, .047μF cap on the singles and .022μF cap on the humbucker. R1 and C1 is a treble bleed mod. If you don't want this, you can leave them out.
It can be done with a 5-way switch. You need a 4-wire humbucker because you need to wire the white/green(BKP wiring color code) to the switch. RWRP single coil should be working fine.
Result: the humbucker will sound full and not too bright and the single coils will sound like on any Fender guitar.
Piplodocus
Cheers. Sounds good. I'll look at it again when my brain is firing on all cylinders again. :)
Quote from: Piplodocus on February 04, 2015, 11:33:12 PM
Just modified my reply.
Piplodocus
I was actually pondering the standard wiring with a 15nF instead of 22nF. This way I'll actually get that slight mid boost when down low as I don't tend to use my tone pots much as is (been watching this interesting series http://youtu.be/RjDwjXN9auY). I guess I could try the Suhr wiring but with equivalent caps for 15uF and say 22-33ish uF for HB/SCs respectively.
Anyone tried lower capacitance for different tone knob flavour? That video makes that idea at least look more interesting to me in principle. Maybe it's not such a good idea, but I don't use tone knobs much as is and they should sound the same when full up?
