Author Topic: emerald bridge for les paul?  (Read 11228 times)
ZECK
Re: emerald bridge for les paul?
« Reply #15 on: April 02, 2015, 11:22:29 AM »
From what you've said, I wouldn't be in a rush to put an Emerald in there. I tried an Emerald in a PRS SE Custom 24 and I found it way too bright in there. If you're after a Mule after a course of steroids, you'd be better off looking at the Abraxas.
@darrenw5094 & @Slartibartfarst42,
the original issue is the wolftone bridge pu in there now is too bright for me.
i have read other posts regarding the emerald and its brightness though others think it quite balanced. those saying it is too bright almost all recommend the abraxas. it seems to get many nods.
thanks for the feed back.
ZECK
« Reply #16 on: April 02, 2015, 11:34:21 AM »
its mahogany body with rosewood finger board. split coil setup. warm but not dark warm i would say.
You should be fine with this wood combination + the Emerald. From what feedback we've given in the forum, you're aware this pickup will feature the high end of the spectrum more than most pickups... and probably in a far more tasteful way than what's in there currently. The thing about Bare Knuckles is that whatever 'emphasis' is designed within the pickup's voicing - it's never obtuse. It's always tasteful. The only reason i've ever changed a BK pickup in my guitar is because they catered to different tastes than what i play - every single one has been brilliantly engineered.
Another thing to throw out there is the fact that the Emerald and Marshallhead bridge are very similar in terms of voicing, as i stated earlier in this thread. Both are brighter voiced, with the MH sounding a bit more aggressive/open, and the Emerald a bit more balanced/compressed. If you're matching up a similar sounding bridge pickup to it's neck counterpart, then that's another consideration towards making the decision towards Emerald. You should be fine, and perhaps even check with Tim/Ben @ BK too if you haven't already.. just for the hell of it. They know their stuff  :wink:
i'm aware of the high end. its that "tastefulness" you mention in that it might compliment well the marshallhead neck pup even with its high end. if its an ice-picky type high end, then no, it wont do in the balance i'm trying to achieve.  if not, from what i read and contemplate from the forum, the Abraxas would the other choice.  or buy both but watching my pennies too.
i am indeed wanting to match up  well with the marshallhead neck pup as i really like it and no one that has listened to it in this guitar says othewise.
i don't want to beat a dead horse any deader than it already is, and you guys have helped tremendously with your advice and time.
i'll email Tim and see what he thinks.  for now, either emerald or abraxas.
thanks
ZECK
« Reply #17 on: April 02, 2015, 12:04:35 PM »
I have different taste in music from you.  With my Les Paul I was after more Zakk Wylde/John Sykes/Doug Aldrich tones.  Off my own back I bought an Emerald set and I thought the hi end was fantastic.  The brightness was lovely but the problem was a lack of girth/bottom end but for blues and rock this may not be an issue.....
Just my proverbial 2 cents
i actually like Zakk's tone/sound with BLS on a couple of cd's i have of BLS.  yeah, i read that for some that lack of bottom end was a deal breaker.  without buying the emerald and trying it in this guitar i won't  know if this "high end" that folks talk about regarding the emerald will be a good match or not.  glad you reminded me.
fdesalvo
    • Frank DeSalvo's Music on Soundcloud
« Reply #18 on: April 03, 2015, 12:02:40 AM »
The Abraxas is a real sleeper and many have no idea just how amazing of a pickup it is.  It's a real chameleon.
ZECK
« Reply #19 on: April 03, 2015, 04:17:45 AM »
as much as i wanted to try the emerald, i ordered the abraxas today from a USA dealer.  the concerns of emerald (might be) too bright won over for the abraxas.
looking forward to trying it out. i have another guitar that would like it if it doesn't work in this les paul. ;-)
really appreciative of all the feedback and help.
« Reply #20 on: April 04, 2015, 03:33:54 PM »
Good choice, if you don't want the bridge to be too bright. Still PAF-flavour on tap, just a tad middier and compressed than a Mule.
gepetto33
« Reply #21 on: April 04, 2015, 03:50:03 PM »
the current bridge pickup in there is a bit too bright for me, an alnico2 ~14.5k.
This does not describe the Wolfetone Marshallhead bridge  :tongue:
Wrong magnet, wrong output... but hey, at least i inadvertently made the comparison to the emerald in terms of brightness! If the MH bridge was too bright, then so too would be the Emerald... even for the sake of it's "tasteful" brightness. The Abraxas was too dark for me even in alder, though darker might be what you're going for now in terms of change.
« Reply #22 on: April 06, 2015, 12:30:54 PM »
he wasn't clear, but he didn't said it was a marshallhead
that matches the fenris model
http://www.wolfetone.com/fenris.html
