Author Topic: Neck humbucker for guys that hate neck humbuckers?  (Read 10644 times)
fdesalvo
    • Frank DeSalvo's Music on Soundcloud
Re: Neck humbucker for guys that hate neck humbuckers?
« Reply #30 on: March 23, 2015, 05:25:58 PM »
Thanks DBM/Alex.
I've found the HxS setup to be really enjoyable configuration on a mahogany tele I play (Abraxas/Apache).  With a push/pull volume splitting the bridge, there are some really great tones inside.  The two pickups I mentioned are an incredible combination and nail vintage tones - power metal with authority.
« Reply #31 on: March 24, 2015, 11:08:01 AM »
Thanks DBM/Alex.
I'm very keen on neck single coil tones, and generally have problems with neck humbuckers when you get to a live situation - flubby, no cut. They are fine at home though.
The solution I've found is to wire the neck humbucker in parallel. I've done this in a few guitars and have been very pleased.
« Reply #32 on: March 24, 2015, 01:25:36 PM »
That's a fine solution. I'm with you when it comes to single coils in the neckposition. The sound of a screaming strat-neckcoil is to die for. I use it a lot on my strat, even more than the Crawler in the bridgeposition.
« Last Edit: March 24, 2015, 02:18:40 PM by Telerocker »
fdesalvo
« Reply #33 on: March 24, 2015, 02:15:46 PM »
I love you guys so much right now.
kauwgom
« Reply #34 on: March 24, 2015, 02:19:39 PM »
I just installed a Manhattan on my Gibson LP studio (neck) and it is gorgeous: great note definition and will cut through the mix I'm sure. It's like a single coil but infinitely fatter without losing the sparkle, can't recommend it more highly.
And surprisingly, when I crank my amp the overdriven sounds are smooth as butter :)
Alex
« Reply #35 on: March 24, 2015, 08:05:15 PM »
I believe BKP once recommended to me using the VHII in a parallel configuration. I never did though.
