Author Topic: NGD: finally finished my SUPER TELE  (Read 12732 times)
Re: NGD: finally finished my SUPER TELE
« Reply #15 on: July 19, 2015, 03:40:27 PM »
Man that is pretty. That wood...oh my. Lovely one. Congrats mate!
« Reply #16 on: July 20, 2015, 12:42:37 PM »
That's a very beautiful guitar!
I didn't know Mastery made a Tele bridge.
Well I did - and I always wondered whether it would change the tone in a way going away from the typical tele tone.
  • Random Solution
« Reply #17 on: July 20, 2015, 01:46:13 PM »
Having seen your guitar I went and had a look at the Warmoth website. It's not exactly a cheap way of getting a guitar but I guess that depends on the quality it is comparable to once assembled. There doesn't appear to be that much work involved once you get the parts as it seems to be just a case of bolting it together and attaching the hardware. How straightforward did you find the whole process and what sort of guitar would you say the finished instrument is comparable to?
littleredguitars2
« Reply #18 on: July 20, 2015, 11:25:01 PM »
putting together something from warmoth is definitely not hard. the only parts i needed some help with was drilling for a bridge ground. for some reason they didnt do it for this body although they usually do on the strats and jazzmasters i've bought from them. and i just needed help securing the bridge pickup to the body safely. if you can set up a guitar, then thats most of the work right there. as long as you order everything correctly everything should be fine. you may need to do a minor amount of fretwork on their necks. inserting the string ferrules on the backs of their guitars is annoying. i wish they did that themselves but its not so bad once you get used to it.
best case scenario its only about $200-300 worth of techwork if you brought it to someone to throw it all together. depending on the guy. maybe even less. i'm still learning but the last jazzmaster build i put together was maybe only 3-4 hours worth of work including the setup. the quality is great and the options you have are much better than a stock fender.
i spent $1100 or so on all the parts for this guitar and i'd say the quality can easily rival a $2000 dollar guitar in terms of quality. maybe more.
« Reply #19 on: July 21, 2015, 08:23:02 AM »
That is because you have a standard tele bridge route in that body. For the standard tele bridge, no bridge ground route is needed - the wire from the string ground is just put underneath.
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
« Reply #20 on: July 28, 2015, 04:27:44 AM »
looks great! time to break it in, would love to hear how it sounds
5F6-A
« Reply #21 on: August 26, 2015, 12:38:05 PM »
very cool indeed
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
"Practice until you can hear the metronome grooving" Carol Kaye
