Author Topic: Crawler Bridge - some new thoughts  (Read 8485 times)
  • Random Solution
Re: Crawler Bridge - some new thoughts
« Reply #15 on: August 04, 2015, 12:12:04 PM »
Exactly, the Rebel Yell is brighter than the Holydiver and so is the 498T and the A-Bomb.
« Reply #16 on: August 04, 2015, 01:39:00 PM »
I haven't used a HD or a RY but I've had the 498T and A-Bomb in the same guitar and I can tell you that the A-Bomb has a lot more mids and treble detail (hair) than the 498T.  It also has more clarity and string separation.  Unless you want raspier mids than the 498T I would recommend looking elsewhere, maybe the ceramic NB or the CS.  I have actually found the CS to sound closer to the 498T than the A-Bomb.
  • Random Solution
« Reply #17 on: August 05, 2015, 08:11:46 AM »
That inherent hairiness in the A-Bomb did concern me. In many ways I find the 498T to be somewhere inbetween the A-Bomb and the Cold Sweat because it seems to be raspier than the Cold Sweat but nothing like the A-Bomb. Perhaps the Rebel Yell would be the answer if that raspy hairiness is tamed a bit.
« Reply #18 on: August 05, 2015, 11:54:01 AM »
I think that the 498T sounds a bit 'thin' compared to the CS.  However I suspect that the RY could be thinner again.  It really needs a guitar with a lot of inherent bass. I think you are right though that the 498T has more rasp than the CS, but the CS has more edge, cut, and bottom than the 498T.  I don't think there is much difference between the 498T and CS in terms of output though, whereas the A-Bomb seems to be a definite output increase.
  • Random Solution
« Reply #19 on: August 05, 2015, 12:19:27 PM »
Mmmm, I never usually like 'thin' sounding pickups so it won't be the RY and I  like that bit of rasp the 498T has so it sounds like BKP may not do what I'm after.
richard
PRS S2 Singlecut RY's
JV Strat  IT Bridge
Gibson SG JB bridge
Fender Bassbreaker 15
Yamaha THR 100 Dual
Quilter Aviator Cub
