Author Topic: Multi-FX  (Read 4874 times)
  • Random Solution
Multi-FX
« on: December 06, 2015, 06:08:06 PM »
This is just a question about effects, not amp modelling as I love my Orange amp.
My amp is a TH30 going through an Orange 1X12 and at the moment I run the following set up:
Guitar - Korg Tuner - 535Q - Hardwire Overdrive - Amp - Boss GE7 - Boss GE7 (for solo boosts) - ISP Decimator - Hardwire Delay - Hardwire Reverb - Amp
All of this fits very nicely onto my pedalboard, though there isn't any spare space. I'd now like to toy with adding a few other effects that I may not use as regularly but the only way I can fit them onto the available space is to go with a more compact option. Two possibilities leap to mind, the Line 6 M9 and the TC Nova System. Both seem to have a good reputation but both have limited routing options and that raises a couple of concerns because all effects will either be in front of the amp or in the loop. I was under the impression that overdrives, distortions and compressors don't work well in the loop and modulation effects don't work well in front of the amp so surely that means I could only ever use half the system in either unit. Is that right? I should point out that I don't mind keeping my existing Overdrive pedal as I don't need a completely all-in-one solution.
The obvious advantage with the M9 is the almost endless options but I believe the overdrives on the M9, meaning I'd certainly keep my Hardwire Overdrive pedal are poor but I could keep the Hardwire Overdrive pedal. The drives on the Nova System are apparently much better but if I used the Drives here in front of the amp, how would that impact on the other effects that are conventionally located in the loop?
A lot of my issues may be down to not understanding how these things work but basically:
1) Which one would work best with my amp?
2) Which of my existing effects would I be best keeping with each one of these options?
Re: Multi-FX
« Reply #1 on: December 07, 2015, 12:23:16 AM »
I would look at the TC Nova. I've read too many issues about the M5 (turning itself on and off etc.) I you don't use the od and cabsim in the Nova, connect it to the FX-loop. The timebased effects in the Nova are really nice and will shine even more in the loop.
Re: Multi-FX
« Reply #2 on: December 18, 2015, 08:06:21 AM »
Maybe take a look at the Zoom MS70CDR.  I have one - it's only a 1 U pedal, the sounds are great.  It's a little fiddly for quick adjustments on stage, but that's the only compromise for having such a useful little unit.
Re: Multi-FX
« Reply #3 on: December 18, 2015, 10:06:45 AM »
Actually the Zoom G5 is a lot of bang for the bucks too, I would sure take a look at it.
