Author Topic: New to the forum and looking for some 8 string Pickups  (Read 5127 times)
joel
« on: May 23, 2016, 07:09:34 AM »
I have a Carvin DC800.  Maple neck through, ebony board, Ash body wings and a maple cap.  SS frets.  I've been thinking about the Juggernauts, Nailbombs, Emeralds, Rebel Yells, and well, anything else anyone could recommend.
The guitar is pretty bright.  They need to be tight pickups, more open sounding than compressed, and super articulate.  I play mostly progressive metal and a smattering of Jazz.
Re: New to the forum and looking for some 8 string Pickups
« Reply #1 on: May 23, 2016, 08:26:31 AM »
I would probably go for Miracle Man or ceramic Warpig here if the guitar is bright.  I would avoid the Emeralds and Rebel Yells, I would think that they might to be too bright for this guitar.  The others mentioned could work
GuitarIv
« Reply #2 on: May 23, 2016, 11:01:05 AM »
Warpigs for Metal and Jazz (Alnico Bridge). Amazing for both styles, played them extensively. If you want something less compressed with enough chunk I suppose Juggs may work as well, but don't take my word for it, that's purely based on hearsay and reviews. I'd avoid the Miracle Man, that one sounds rather sterile for cleans. In any case shoot the BKP staff an E-Mail, they know their stuff  :smiley:
Cheers
joel
« Reply #3 on: May 23, 2016, 01:54:45 PM »
Thanks for the recommends.  I'm coming from having active pickups.  So anything will be an improvement.  The only BKPs I've played on are the Juggs.  Chunky for sure.  Cleans sounded great too.  But I didn't get to spend much time with them and not on an amp I'm very familiar with.  It was a Mesa Mark V:25.  That amp sounds pretty good in general, but I'm more of a hot rodded Marshall kind of guy.  Like Fortin or Peters amps.
metale
« Reply #4 on: May 26, 2016, 09:34:48 AM »
Hello.
I've got a Painkiller 8 on basswood and it surprised me as not-so-middy-and-bright-as-I-thought, but I won't recommend it in your case.
I agree with the Juggernauts being a good choice, but I'll also throw the Holydiver in the mix, especialy as it does split/parallel so well and works so good in bright guitars.
joel
« Reply #5 on: May 26, 2016, 04:49:58 PM »
Thanks!
The Juggs sounded weird when I played them the first time.  Wooly.  But articulate.  I didn't know how to take it.  Only about 10 minutes of playing on a Misha Sig through a Mark V 25.  Right afterwards I played a Suhr.  So I think my judgement was partially my expectations and partially colored by the next guitar, and partially that amp.  Which I found to sound really compressed.
« Reply #6 on: May 26, 2016, 04:58:03 PM »
You know, I stick by my hunch of a ceramic Warpig in the bridge after reading the following post over at sevenstring dot org from someone who has one in a Carvin DC800:
Quote
My favorite pup. I'v got one in my DC800. I'v also had the 6 and 7 string versions of the pickup. (All ceramic)
If your wanting insane grinding metal, these do it. If you roll back the volume, they will do everything else. My go to pup. If i didnt play grinding ....ed up death metal though, i probably would go with something else.
There is more discussion of the ceramic Warpig in an 8-string and clips in the thread
http://www.sevenstring.org/forum/pickups-electronics-general-tech/274653-bare-knuckle-warpig-8-string-pickups.html
« Last Edit: May 26, 2016, 05:00:25 PM by Agent Orange »
joel
« Reply #7 on: May 26, 2016, 11:15:17 PM »
I've had 3 DC800's.  All sounded really different based on the wood used.  This one is Ash wings and Maple neck, ebony board.  Sounds totally different than the all walnut one with a Maple board I used to have.  It was more compressed and narrow sounding with a huge mid range.  And louder.  This one sounds scooped and more articulate.  I'm not convinced I'll be able to get jazzy enough tones out of it.
hussamj
  • BKPs: Black Dog/Emerald, Nailbomb
« Reply #8 on: May 27, 2016, 12:11:47 AM »
The juggernaut neck pickups sound very jazzy and creamy when playing some single notes and leads. So, that's a great jazz pickup. The bridge is great for progressive stuff too, very responsive and chunky. You might find it a bit bassy but nothing that eq can't fix.
joel
« Reply #9 on: May 27, 2016, 01:38:04 AM »
I play through a Randall Thrasher.  I can cut the bass befor it hits the gain stage.  I just want my low string to sound like a piano.  Pretty sure the Juggs will be the puckups.
GuitarIv
« Reply #10 on: June 27, 2016, 04:46:46 PM »
Share em results once you get em installed!  :grin:
Cheers
