Author Topic: Music Man JP15 Replacement Pickups  (Read 15859 times)
  • Random Solution
Re: Music Man JP15 Replacement Pickups
« Reply #15 on: June 05, 2016, 07:15:31 PM »
Big thanks for your reply. I am not sure the Nailbomb is working for me. When I bought the Jackson about 8 years ago I emailed Tim, saying my concern with the maple through neck and the Floyd Rose was that the sound would be a bit thin. Hence he recommended the Nailbomb. Living in New Zealand made it a bit tricky to send things back, and it certainly wasn't thin sounding. I would definitely like something smoother and sweeter. Just out of interest, what did you end up with in your SL3?
Sorry for the late reply but we're moving abroad so things are a bit hectic right now.
The A-Bomb wasn't 'thin', in my SL3, it just had a lot of upper mids that tends to sound a bit aggressive, which was accentuated in my opinion because maple neck-thru guitars tend to be middy, especially in the upper mids. I just thought the A-Bomb would be more at home in mahogany with a Les Paul probably being ideal so I'd buy another one, just not for a maple neck-thru. I tried two further pickups in that guitar and both were more successful. First up was the Holydiver, which sounds odd because that pickup has plenty mids but unlike the A-Bomb, the mids are more evenly spread instead of being concentrated in the upper mids. The 44AWG wire used in the Holydiver also helped to smooth things out as the 43AWG used in the A-Bomb tends to be more raspy. I liked the Holydiver a lot in that guitar.
Next up for the SL3 was a Miracle Man. This is going to sound odd because when you look on the website, the Holydiver is alnico with a load of mids while the Miracle Man is ceramic with scooped mids but in actual fact, these two have an awful lot in common. Both are very smooth and despite being ceramic, the Miracle Man is surprisingly warm sounding. The idea of it being scooped is a bit misleading; it has mids it's just that the 'mid mids' are moved a bit either side so it has a bit of a scooped feel while still having a mid-range presence. I was looking for a pickup that was essentially a Holydiver with a tighter and slightly more aggressive bottom end and more screaming highs for solos but findamentally in the same ballpark as the Holydiver. BKP said I'd basically described the Miracle Man and that's how it turned out to be. The Miracle Man is just a bit scooped where the SL3 has most of its mids so the two go together extremely well.
andrew_k
« Reply #16 on: June 05, 2016, 08:03:50 PM »
Well mine is a JP6 so ...
This really is a huge help, big thanks for taking the time to reply, much appreciated
andrew_k
« Reply #17 on: June 05, 2016, 08:06:29 PM »
Sorry for the late reply ...
Thanks for this, I didn't realise that about the Miracle Man. I would be interested in trying one in my SL3 at some point in the future.
'Ash' J. Williams
« Reply #18 on: June 06, 2016, 12:59:56 AM »
I would like to add to what Slarti said about his experience with the NB in a maple neck thru.
I had basically the same (somewhat negative) one with a Maple NeckThru/Swamp Ash wings ESP Horizon some years ago.
The NB bridge was pushing too much upper-mids frequencies making it always far too much agressive.
The HD pretty much solved this problem completely.
OTOH, I put some NB in a Basswood Ibanez later on and it's fantastic : those uppermids emphasis actually shines in the basswood RG making the guitar sing and I now understand the NB's vintage DNA that some guys here loves.
ABb/VHIIn/CRb/IT/EM/HD/EM/BD/Juggs/AM/Mules/A5 NB/MthrMlk
Had: PGs/SMn/PKb/A5 BH 6&7/CS/MiracleMb/RRn/
fdesalvo
    • Frank DeSalvo's Music on Soundcloud
« Reply #19 on: June 13, 2016, 05:52:30 PM »
Had to log in for this comment - I feel the Abraxas splits better than the Crawler (in my exp)- more twang and sparkle.  The Crawler produced a thicker sounding split.  No doubt - that pickup is really thick and smooth.  Probably the best lead tone and feel in the line for me.  I love how the Abraxas is finally getting some spotlight as of late.  It's my fav bridge humbucker of all time and is strong enough to stand alone in a single pickup guitar thanks to its amazing split clean tones and versatility.
Cheers
