Bkp neck like cs bridge
Started by jase2677, October 30, 2016, 01:05:04 AM
jase2677
Is there a bkp neck pickup that responds like a cold sweat bridge ??
JimmyMoorby
Quote from: jase2677 on October 30, 2016, 01:05:04 AM
I'd message BKP direct but maybe the painkiller neck...it's a combo many have used before with good results too.
neck nailbomb has a somewhat similar voicing, but I'd pick the neck painkiller
but you shouldn't dismiss using an actual bridge cold sweat in the neck position
jase2677
Is the Holy Diver neck in the same ballpark at all ?
I would have thought that the HD neck would be closest.  Depending on the guitar you might be able to get away with a RR neck too
JimmyMoorby
#6
Painkiller neck without a doubt.
It's not an aggressive neck pickup per se but its is powerful and cutting whilst still sounding like a neck pickup should.
Think EMG 81 ballpark but with boutique/passive/more natural tone.
The painkiller bridge isn't a million miles away from a cold sweat the huge difference comes in the mids and a little less output where the cold sweat has subtle mids and the painkiller has AGGRESSIVE mids.
The painkiller neck picks up where the bridge leaves off without the aggressive mids and a little less power........like the cold sweat bridge you could say!
You can round off the highs and lows of the painkiller neck with a pickup cover but really it's a damned good neck pickup really good for metal shredders but as with the emg 81 it will surprise you with how good it is for cleans and other styles.
BKP lay waste to EMG's in the bridge position and they make excellent neck pickups but an emg 81 in the neck.....it gives you way more possibilities than you'd think and the neck position on any guitar just warms things up in a natural way even when using 'sterile' actives to my ears
