Author Topic: Compressor pedal vs Maxon OD808 to thicken up the tone  (Read 27144 times)
Lucas
Re: Compressor pedal vs Maxon OD808 to thicken up the tone
« Reply #15 on: December 13, 2016, 08:33:36 AM »
I haven't used it but all MXR pedals seem to have a good reputation with gain and this one does too, and according to that link above it works well in front of the amp.
Avoid the simpler chorus pedals.  The low, high, and depth controls can be quite useful
I`ve read that thread and someone was complaining that apparently MXR was too noisy in front of the amp. Then that person changed it to TC Electronics Corona chorus and it was perfect.
« Reply #16 on: December 13, 2016, 12:41:51 PM »
That's strange, you'd think it would be more likely to have noise problems further down the chain. I have mine after all of the noise reduction, EQs, and gain and it is not noisy.  Might be the case that the pedal was faulty.
Plenum n Heather
« Reply #17 on: December 14, 2016, 12:42:24 AM »
Best way to thicken a guitar tone is to add very short delay via modulation,  detuning effect, or double track pedal.
« Reply #18 on: December 14, 2016, 11:20:06 AM »
A lot of people run a Carbon Copy on a short delay for that reason
« Reply #19 on: December 14, 2016, 04:01:37 PM »
I've been through all kinds of overdrives throughout the years
sd-1, ts9, ts9dx, od9, od808, some analogman and keeley maxons, and some tube driven maxon
they worked really well, but they always add the "scream" effect
lot of bass cut, lot of midrange boost and that extra tightness that is great for metal, but that definitely changes the amps tone
I've tried a few equalizers as well, and had good results with some old' 81 blue maxon 6 band eq, that made my sound tight and crunchy without changing much of the core tone, but also added a ton of noise
if I was going back to play metal only, I'd still be happy with a tube screamer type overdrive
these days I've been enjoying a tc electric classic sustain parametric equalizer
it has a control for compression, another for output and a simple single frequency range parametric control with a peak/notch control
it doesn't add a lot of gain like an overdrive and doesn't cut anything unless you dial it as a frequency cut instead of a boost
I love how I'm able to add some actual compression, a little output and boost the center mids without making the amp sound like it's shooting lasers
my tone is now less "squished" and focused, so I might sacrifice a little low end tightness but I get much thicker lead and rhythm tones, and also better dynamics than when I used overdrives
if you wanna preserve the amps tone and just add that extra oomph in your picking and sustain without sounding super tight and aggressive, there are plenty of boosting options these days
if I didn't acquire the classic sustain in a trade (I traded my tube driven maxon tbo-9, by the way), I'd probably buy the tc spark boost or a pigtronix philosopher's tone micro
the bogner harlow sounds interesting too
https://www.youtube.com/watch?v=G3oCA_ui9aQ
https://www.youtube.com/watch?v=uywswAOwCU0
https://www.youtube.com/watch?v=JL1K9EY4z_g
Lucas
« Reply #20 on: December 14, 2016, 06:05:16 PM »
I actually have Xotic EP booster at the end of the chain for volume boost. At this moment it`s at the end of my pedal chain but still BEFORE overdriven amp.
I wouldn`t mind a little bit more gain while boosted but just a bit.
Was thinking about chorus pedal as it would add some depth to cleans as well, but I`m little afraid to use it in front of the amp.
so you recommend Tc electric classic sustain parametric equalizer to run it at the beginning of the chain and while still using EP booster as a volume boost for solos?
Basically I need something to tight the tone up, add some 'depth' on both distortion and cleans. Ideally I would keep that pedal on all the time regardless the channel I`m on, plus I would keep EP Booster for volume boost on solos.
I already know that compressor pedal that I have laying around idle is not a good option.
Lucas
« Reply #21 on: December 14, 2016, 06:26:30 PM »
It`s getting quite confusing. To simplify my current set up is:
-Orange Dual Terror Amp (no FX loop), I use one channel clean, one fully distorted.
pedals as stopped using distortion from stomp boxes:
-Dunlop Wah
-TC Electronics Flashback delay
-tuner (but here it`s not important)
-Xotic Ep booster
-Wampler Ego Compressor pedal (not using that at all for ages, would it be useful if not I will sell it)
so chain is:
guitar -> tuner -> wah -> delay -> Ep booster (volume boost for solos) -> front of the amp
I don`t play any extreme metal to be super tight and super aggressive (my Ceramic Nailbomb and Miracle Man pickups are aggressive enough). I need something ideally staying always on to thicken the tone up, balance it, give it a bit more gain and sustain (my Orange amp lacks a little tiny bit of gain), smooth a bit everything and give more 'depth' on both channels. I play rock/heavy rock/metal. I would say Metallica, Black Label Society, Killswitch Engaged would be the heaviest styles I play.
Maxon / Tubescreamer will make it more aggressive?
Compressor will be useless for that application?
Chorus will sound bad in front of distorted amp ant too messy?
« Reply #22 on: December 14, 2016, 10:36:04 PM »
if you can find one for cheap, yes I do
it was like 300 USD new, but I got it in a really good trade with lots of cash on the other guys side
mine is the reissue version, but people on internet claim that the original 80's version is better
as I said, it won't really work as a "tightener" as well as an overdrive as it won't cut the low end, but it with proper setup, it will thicken up your tone if you add some mids and a little compression without adding a lot of bass like a real clean boost pedal  like the ep booster would do, so it does make you sound tighter
I'm still able to get pretty tight KsE-like tones with my short hydra (basically a lp custom) loaded with a holy diver/emerald set
the more mids you add, tighter and more overdrive-like it will sound, up to a point it will start sounding like a crybaby
adding lower mids or upper mid range sounds great for some other stuff, though, but I tend to focus on the center mids
it works great as a mid cut too, so you can clean up a distorted channel instead of boosting it
I use it right after the wah and before everything else
jerry cantrell crybaby -> planet waves tuner pedal -> tc classic sustain -> boss/ibanez/visual sound delays/choruses -> hush noise suppressor -> modded '73 marshall
if I add my oliver roland licensed sd-1 clone or my lovepedal superlead, it will be right after the compressor
I'm pretty sure there are other compressor pedals with similar mid boost or eq features, though
if you don't need an actual compressor, you could try an actual parametric equalizer with more band controls instead
that would probably do the job for me too
the advantage of having both things is that I can add a little more sustain from the compressor and not just the extra sustain from pushing frequencies into the amp input stage
1 - I love them, but yes, they tend to sound aggressive in comparison to the non-overdrive alternatives
2 - not really, as you can still get better sustain without using a lot of gain in the amp
I personally don't like setting a lot of gain in the amps, as most of them tend to get flubby and bassy when the gain control is set high, even if they're not really high gain amps
plus, turning a pedal off can help you go back to cleaner sounds without messing with the volume controls in the guitar, which can be much more confusing for some people (like me)
3 - SOME chorus pedals can sound good in front of  a distorted amp, but they don't just thicken up the sound
a chorus in the front will always give a certain vibe that's different from the natural sound of an unmodulated distortion
there's always that early Alice in Chains/Zakk Wylde thing going on, which can be desirable or not
« Last Edit: December 14, 2016, 10:39:19 PM by Eric Hellstyle »
Lucas
« Reply #23 on: December 15, 2016, 12:38:36 AM »
TC classic sustain unfortunately is too expensive at the moment for my budget.
I must say that TC Spark boost sounds interesting. So I`m left with 2 options actually (I gave up an idea with chorus anyway).
1. TC Spark boost (would give an edge and bit of 'breakup tube sound' on cleans plus gets valves cooking more on drive.
2. compressor pedal (which I have and dont use at all), but I`m totally unfamiliar what settings would do the job for me. I would like to keep it either TC spark boost always on regardless channel I`m on.
thanks again for great help!
« Reply #24 on: December 15, 2016, 01:40:20 AM »
If going with the Spark Boost I would go for the full size version, not the mini version with one knob
Lucas
« Reply #25 on: December 15, 2016, 08:23:31 AM »
Full version definitely. Mini one reminds me of my Xotic Ep booster
Would Spark boost be my best option?
« Reply #26 on: December 15, 2016, 12:38:45 PM »
I've only ever used the MXR/CAE MC401 boost, which just has the one knob.  More knobs will give you more adjustment, so I assume that's a good thing
« Reply #27 on: December 15, 2016, 01:41:35 PM »
I've had 2 spark boosts and ended up selling both. Versatile but I didn't like what they did to the tone, can't really explain it. I wouldn't use a tubescreamer type pedal to fatten,  the opposite actually!
I've just built a Fuzz Dogs clone of the LPB-1 and it's perfect for fattening and adding saturation. The original pedal was actually cheaper than the clone but I wanted the smaller form factor of the clone (it's tiny!). The ehx one is really cheap and I'd say well worth a try.
« Reply #28 on: December 15, 2016, 02:06:34 PM »
If you want a fat sound you could try an Earthquaker Devices Acapulco Gold pedal, but be careful what you wish for ...
https://www.youtube.com/watch?v=neazXtE5mPE
Axe Palace
    • The Axe Palace
« Reply #29 on: December 16, 2016, 05:10:33 PM »
I'd strongly suggest people used to a Maxon or Ibanez OD try one of the following pedals, which IMO are far superior:
1) Mesa Boogie Gridslammer - Slightly darker edge to it, but extremely tight and musical. Will let more of the natural sound of the amp come through. My favorite pedal to use in front of brighter amps.
2) MXR GT-OD - Essentially a TS808 clone but with more of a transparent sound. Tightens the bottom end but lets more "good" lows in and no annoying mid-hump which can thin out your sound (which is why I hate the Maxon).
3) MXR Custom Badass OD - Similar the one above but takes it even further with the 80hz knob. Whats cool about this is it will do all the good things we all love about OD pedals, but lets you control exactly how much "good" low end is in your mix while still scooping out the sub-bass frequencies which mud up your sound. Also this pedal is a bit more aggressive sounding than any other OD pedal I've heard, yet still doesn't color your amps sound too much.
Really all of these have the classic TS tightening effect, with added sustain and hitting your amp harder, but without the obnoxious upper mid honk and thin bottom end you get from something like the Maxon. In essence, it does all the good things people like but while letting more of the amps natural sound to come through. I never use Maxon or Ibanez ODs anymore since I discovered these.
I personally prefer the Mesa/Boogie Grid Slammer the most, in terms of not only tone but quality. It brings out the best of my ENGL, Mesa, VHT, and Soldano amps I tend to play a lot. For those who own a PRS Archon 100 head, its definitely makes that amp sound better than any other pedal I've tried as sell.
« Last Edit: December 16, 2016, 05:13:11 PM by Axe Palace »
THE AXE PALACE - PROUD TO BE THE #1 BKP DEALER WORLDWIDE - www.axepalace.com
