Author Topic: Help with wiring bass roll off to bypass  (Read 9323 times)
Ajrtucker
« on: March 23, 2017, 10:31:05 PM »
Hi all. Working on a tele custom (Bridge single, neck wide range) by adding a 6 position free way toggle switch. Wondering if i can get some advice on it's wiring. The guitar is currently wired with a standard three way toggle, along with a push pull to split the neck pickup and bass roll-off control also on just the neck pickup. What i'm trying to do is remove the push pull and have the sounds on tap on the switch like so:
1 and 4: Bridge Pickup
2: Both Pickups
3: Neck Wide-Range
5: Both Pickups (Neck Pup Split)
6: Neck Wide-Range (Bass roll-off active)
It all seems do-able. My only question is how can i wire the bass roll off so that it only affects position 6 and nothing else? Hope you guys can help. If i'm not making sense, please ask
