Humbucker Size BKP-90
Started by Steve-Mr Pig 2U, May 24, 2005, 07:50:27 PM
Funny, the Mule sounds so much  friggin' louder in the soundclips. Or is that because of the amp you're using, Tim?
Tim
No,it's just the way they've been recorded. Remember, a lower output pickup will compress the front of the amp less and sound bigger to a certain extent.
Tim
The HB sized P-90 is loud!  It is louder than my mini-Mule, even though the mini-Mule is in the neck position and the P-90 in the bridge.  However the tone is briliant so I am quite happy to live with the extra volume!  Perhaps I should have gone for alnico V in the min-Mule (I think mine has IV's), but I never expected so much sound from an 8K P-90.
It is also pretty quiet until the gain is turned up.  I guess the metal cover makes a kind of Faraday box for the pickup and helps cut down the hum.
The coil tap changes the voicing more than the volume.  It gets less mids and a brighter tone on the tap.
Tim
I put the tap in at 1500 turns from the end of the coil so what you're hearing is stock at the tap and overwind on full. A typical overwind brings the mids up and the highs back in equal percentages.
The reason the P90 is SO pokey is there's 2 vintage cut Alnico Vs in there as opposed to a single much smaller Alnico IV in the Mini Mule.
Any chance of some clips? :D
Tim
