Hi,
I'm going to document some of my experiments here in case others come across it. I guess it's a fairly common guitar to want to upgrade.
One thing to note: I bought the BKP 550k push pull pots, replacing both volume and tone. The Alpha pots that were there before were 1-2mm narrower in diameter so I had to carefully file the holes to be slightly bigger. Mildly scary but worked ok. I followed this guide using the tools I had:
https://youtu.be/bKNAkTWC4xASecondly I ended up re-doing all the grounding and wire routing inside the cavity using push-back cloth wire (also from BKP). It just made it neater and easier to understand what was going on.
Anyway, the current wiring is:
- Volume pot push/pull is used to reverse phase on the neck pickup.
- Tone pot push/pull is used to split both coils using standard coil split wiring.
- 0.022f Russian tone capacitor from BKP.
- 3 way blade switch.
Basically
https://www.bareknucklepickups.co.uk/upload/support/20_132fcee.pdf mixed with
https://www.bareknucklepickups.co.uk/upload/support/1_hum_4_con_pushpull_pot_phase_reversal_with_another_hum_c8e3961.pdf (for the neck pickup and volume pot).
The sound file is a rough play through of the same sounds on all the settings in this order, played through a model of a Fender Pro Reverb.
Neck humbucking phase normal
Neck humbucking phase reversed (which I suppose is pointless)
Neck split phase reversed (which I think means it's using the inner coil?)
Neck split phase normal
Middle humbucking neck phase normal
Middle humbucking neck phase reversed
Middle split neck phase reversed
Middle split neck phase normal
Bridge hum
Bridge split
