Author Topic: Wiring from SD Invader to BK Nailbomb  (Read 51863 times)
danny@
« on: September 03, 2022, 07:40:38 PM »
I'm doing 4 wire split coil on the Invader with my lespaul but the number of wires on the nail bomb diagrams don't match up. The image of the invader wiring is attached.  Any pointers of what wire on the BK wires should be swapped would be appreciated!
Re: Wiring from SD Invader to BK Nailbomb
« Reply #1 on: September 07, 2022, 05:11:10 PM »
There's loads of wire diagrams etc here: https://www.bareknucklepickups.co.uk/support
Includeing, under FAQ, this:
WHAT IS THE BARE KNUCKLE "FOUR CONDUCTOR COLOUR CODE"?
The colour code we use goes like this: Black: Start of screw coil; White: End of screw coil; Red: Start of slug coil; Green: End of slug coil. For standard series operation, solder the red to the pot tag, the black to ground (usually the back of the pot casing) and solder the green and white together.
