Author Topic: Setup advice.  (Read 79284 times)
themetallicat86
  • BKPs: VHII bridge, Stormy Monday neck.
Setup advice.
« on: April 12, 2024, 09:29:47 PM »
To the point first: I have a constant problem with my 6th string buzzing on the first fret of I pick too hard (unless the string tension is high, like my 10.5-52 gauge strings tuned no lower than E flat, and even then I can't be very aggressive).  I don't go crazy (no Pete Townsend impersonating), I even started using thin picks (0.6mm) and retrained my right hand to pick lighter and more deliberately.
I visually checked the nut slot height by pressing on the third fret of each string to make sure there's a bit of space between each string and the top of the first fret.  The neck has just a shade of relief in it (pressing down the sixth string at the first and last frets I can see a thin gap between the string and the middle frets).
Am I just too ham-handed?  Should I put a bit more relief in the neck?  Should I consider having a new nut cut?  Any/all advice is greatly appreciated.
themetallicat86
Re: Setup advice.
« Reply #1 on: April 12, 2024, 09:44:55 PM »
Or, a suggestion for myself, maybe I should just focus on playing better  :smiley:
