Author Topic: Mule/Rebel Yell  (Read 12972 times)
Minoraie
Mule/Rebel Yell
« on: July 21, 2024, 08:08:58 PM »
I have a Gibson Les Paul Satin Standard and I need some new pickups in it. I love The Mule and Rebel Yell but I want something in between. I want it to be as versatile, dynamic and articulate as can be. It's also important that the highs never gets harsh.
What pickups for bridge- and neck position would you recommend?
Favorite guitar tones are George Lynch, John Sykes and Gary Moore "Hard rock era"
« Last Edit: August 12, 2024, 12:35:00 AM by Minoraie »
timmy_pix
Re: Mule/Rebel Yell
« Reply #1 on: July 23, 2024, 09:14:03 AM »
In between Mule and Rebel Yell, versatile, dynamic, articulate (not articulated, unless you want it to also work as a lorry)... to my mind, you're describing the Black Dog.
Tight but full low end, mids with the same kind of smoothness as the Mule but stronger/more pronounced and less chewy, but keeping the PAF openness/character; less compressed than the Rebel Yell and wider mids, not as focused in the upper mids. The Black Dog is listed as vintage hot but in many ways it's more "low-output modern"; it takes gain like a champ and where some hot PAF designs feel like they're bursting at the seams, the BDs feel like they've got plenty of headroom, which is where you get the dynamic quality. Aggressive but open, focused but clear. The neck feels more PAFy, but again, has that more modern edge where the attack is a bit quicker than PAF designs and the pick attack clearer.
That said, your 80s rock heroes would lead me more towards the Holydiver/Cold Sweat/Rebel Yell.
For comparison's sake, the Holydiver bridge is more compressed, thicker in the mids, smoother in the top end, and has a singing quality (as opposed to the Rebel Yell scream); the neck also sings and is a very bright, articulate neck pickup. The Cold Sweat bridge is surgically tight, thick tight bass, bright open high end and scooped feeling mids (they're there, but the bass and treble are more dominant). It can feel stiff at times though, particularly in the wrong guitar. The neck is phenomenal - juicy, full, clear, percussive, just the perfect lead pickup for shreddy stuff.
All that said, pretty much any pickup will do the ones of your heroes through the right amp/pedals - I've been revisiting the first two Gary albums recently and they are the Greeny LP and his 61 Strat just through a Guv'nor/DS1 and Marshalls cranked to buggery. So with all that said about the other pickup designs, from your initial brief, I'm very confident in recommending the Black Dogs.
BKPs owned:
Stormy Mondays, Mules, Emeralds, 10ths, Mothers Milks, Nantucket, Black Dogs, Holydivers, A-bombs, Warpigs, Sinners, Cold Sweats
Minoraie
Re: Mule/Rebel Yell
« Reply #2 on: July 28, 2024, 04:46:45 PM »
Thanks for the input. I will definitely check out Black Dog.
Re: Mule/Rebel Yell
« Reply #3 on: August 12, 2024, 06:01:03 PM »
I'd say the Riff Raff with a mild eq boost or overdrive gets right in between the Mule and Rebel Yell territory and I like it better than both Mule and RY (or anything else), but the tones you mentioned definitely could use something hotter...
I'd take the Emerald over the Black Dog in that case (although I complety agree with timmy's descriptions), and I would also consider the True Grit and the Holy Diver
