Author Topic: Speaker choice  (Read 4615 times)
DeanS
Speaker choice
« on: May 31, 2006, 10:56:22 AM »
I shall be speccing up a small speaker cab for my Nano and was wondering if anyone had any views on speakers and their character/sounds. I've never been convinced by the V30's and want something with an earlier break up /gritty sound to complement the nano etc.
Ideally 16 ohm and any size from 8'' to 12''
Cheers
Mothers Milk set, VHII
Underground_Player
Speaker choice
« Reply #1 on: May 31, 2006, 12:17:31 PM »
Check out the speaker clips on this site:
http://www.proguitar.de/AudioDemo/AudioDemo.html
...as posted by hunter in the Time Out section. :)
The differences between the speakers here is pretty accurate.
In my opinion you need a G12M, but bare in mind that you'll have a job overdriving any speaker with Nano power.
Some Celestion's aren't as sturdy as they once were (for once I can safely say.....fact) but again with Nano power you shouldn't have any probs.
Mostly Harmless
DeanS
Speaker choice
« Reply #2 on: May 31, 2006, 12:25:25 PM »
Underground, thanks for that, I think the Jensen is closer to what I'm looking for....
Underground_Player
Speaker choice
« Reply #3 on: May 31, 2006, 12:29:10 PM »
Fair enough. Glad I could help. :)
Mostly Harmless
Speaker choice
« Reply #4 on: May 31, 2006, 01:17:50 PM »
Out of curiosity: why a small cab?!
I played the Nano thru a 4x12, and thought it did a great job, as does my other uber low-powered amp, the venerable Smokey!
mikeluke
Speaker choice
« Reply #5 on: May 31, 2006, 01:23:27 PM »
I'll throw another thought into the ring. Have you looked at/considered Eminence speakers? The Patriot range are more US-like (Jensen) and the Red Coat range more Celestion-based.  Worth a look
Mules, Riff-Raff
DeanS
Speaker choice
« Reply #6 on: May 31, 2006, 01:47:34 PM »
Twilight, I'm looking at a small cab and relatively low efficient speakers as I want to keep the volume to a minimum when running the Nano flat out.
Also don't know whether its due to speaker flyback (back emf's of a larger speaker) but sustain is better when using the inbuilt speaker than with a V30?? I know the inbuilt speaker was included for fun more than anything else but it does have some good qualities as well a some bad ones!
Speaker choice
« Reply #7 on: May 31, 2006, 02:58:08 PM »
Quote from: DeanS
Fair enuff. :)
Elliot
Speaker choice
« Reply #8 on: May 31, 2006, 08:18:22 PM »
Have you considered  2 x Celestion Tube 10s set in Award Session Pilot cabs- top quality and not going to knock walls over.  Session do 1x12s too.
http://www.award-session.com/amplifiers_cabinets.html
DeanS
Speaker choice
« Reply #9 on: May 31, 2006, 08:58:44 PM »
Elliot, like the sound of the tube 10's! After some quick web searches it seems that they like to break up/distort very early on- just what I'm after!
Probably go for a 2X10 in parallel for 16 ohms
Thanks
