Author Topic: Power tubes failing?  (Read 8560 times)
« Reply #15 on: June 15, 2006, 10:10:26 AM »
Quote from: deg0ey
Can the Peavey take both? I know there's some that can do both, but i didn't think the peavey classic was one of them
The Peavey classic 50/50 takes 8 X  EL84 valves - small ones like in a Vox AC30
The older Peavey classic 60/60 used 4 x 6l6GC
maliciousteve
« Reply #16 on: June 15, 2006, 01:12:01 PM »
« Reply #17 on: June 15, 2006, 06:23:39 PM »
Yeah - they look just fine
maliciousteve
« Reply #19 on: June 21, 2006, 12:20:19 PM »
Ok so i put in my new tubes. When i first started it all up, the sound was fine and i had a much more 'fuller' tone. I turned it off, put the poweramp back into the rack case and i get this hum. I can still get sound out of it, but i get an annoying amount of hum when i stop playing. Now there's nothing in the room or downstairs that can interfere with the signal so it must be something else. Any one help?
« Reply #20 on: June 22, 2006, 06:28:22 PM »
sounds like you have a ground loop in your rack case - try isolating the rack from the case with those plastic washers.
 :twisted:
