Author Topic: NI Kontakt 2 users!  (Read 3551 times)
Peterku
NI Kontakt 2 users!
« on: June 24, 2006, 01:01:34 AM »
Hello,
There are some loop sets in Kontakt's own sample library and a few of them behave quite differently than the others: unless I stop pushing the keys on my keyboard, Kontakt will keep looping the samples, and will play the samples till the end for a last time even when I've already raised my fingers. In other sets Kontakt will immediately stop when I raise my fingers from the keyboard, and won't loop the sample even when I keep the keys pushed down.
Is there a place where I can change this setting? I couldn't find that part in the manual... :(
NI Kontakt 2 users!
« Reply #1 on: June 24, 2006, 03:36:05 AM »
Hmm, I don't think you can change the length of the individual sample.
I've had the same issue, too, but came up with nothing.
You could re-sample the sample, as it were, and then edit the .wav down and use that as a seperate sample, but ... that's a lot of work!!
You can try the NI forum, but forewarned -- a lot of jerks on that one!!
Peterku
NI Kontakt 2 users!
« Reply #2 on: June 28, 2006, 02:24:17 PM »
Thanks, Ben. I THINK I've found the solution. Kontakt has a Script Editor part that has functions such as Midi Latch, Retriggering etc. Now I only need to find the proper setting for these functions.
