Best (affordable) guitar w/P90's?
Started by cjpmmd, June 30, 2006, 09:18:17 PM
sambo
i dont see the point in getting an LP junior over the MM... not for the extra money... unless your craving for two pickups of course...
Sifu Ben
A) It looks better
B) I't's got a second pickup
C) It's got the "proper" Gibson headstock (the MM one really turns me off)
D) Did I mention it looks better?
I quite fancy one of the singlecut SE soapbars (there's still a few around) and they're supposed to be quite good. The Gordon Smiths are super cheap and well thought of.
sambo
1.) looks are personal preference.
2.) second pickup isnt NECESSARY... again its preference... and not worth £100 extra in my opinion..
3.) theres no way in hell id pay more good money for a different shaped headstock  :?
4.) again.. i actually prefer the look of the MM...
CaffeineJunkie
Quote from: Sifu BenA) It looks better
+1, sorry sambo, but i don't think anybody should be derived of the second pickup in a guitar
sambo
Quote from: CaffeineJunkie
haha! im sorry but that is utter bullshiteee... i really dont think a second pickup is that vital... not in the slightest... i have more than enough options using my amp/tone control/coil tap.... all in one pickup... i havent missed a second pup in the slightest... in fact i prefer just one cause its simple... and like tom said- its more rawk...
Quote from: sambo
any less than 3 pickups and you're just softcore, lol :wink:
CaffeineJunkie
Quote from: sambo
having the coil tap is essentially having two pickups anyway
sambo
^exactly!.... so you dont need 2 pickups at all...
CaffeineJunkie
so what about when you want to go from a Led Zep style riff to a GnR style solo??? how you gonna do that with your coil tap?
deg0ey
You use a different guitar...Noone's saying it can cover everything, just that it's not useless because it only has one pickup
To be honest, I'm thinking of getting a guitar with P90s but the MM is just ugly to my eyes - I wouldn't be adverse to it only having one pickup though
Sifu Ben
How do you coil tap a P90  :?
Anyway, if you wanted to retrofit a melody maker with a neck pickup and a scratchplate, you're looking at £80 for the pickup and £25 for a scratchplate that size and shape, so you've spent £105 before you've even paid a luthier to rout the new cavity and fit it for you, as well as fitting the switch and 2 new pots and knobs (another £20), so you're looking at the best part of £200! How again is it not worth that?
I really hate this weird "one pickup is more rock" reverse snobbery. What are you really saying? "I'm going to intentionally limit myself as a musician because it's more rock" ?????
Bottom line is that you cannot get the same sounds or qualities from a bridge pickup as you can from a neck pickup, and some fantastic rock sounds have been created using the neck pickup, just ask Clapton, Hendrix, Page, Blackmore, Slash etc.
Sifu Ben
degOey, it's more than likely that you're going to want to play crunchy riffs and fluid leads in the same song.
We weren't the ones saying 1 pickup was useless, the 1 pickup brigade is saying that the neck pickup is pointless  :roll:
Even Van Halen has started using the neck  :o  :shock:
deg0ey
Well, you need to look at what a coil tap is to understand how one works on a P90...a coil tap is (to my knowledge) a wire coming from a pickup so that it doesn't use all the coils of wire - thus limiting its output and changing the sound
The reason people get confused is that the term is used interchangeably with coil split (using only one half of a humbucker) by many people, which is technically incorrect :wink:
(although i could be wrong on these definitions lol)
EDIT: I think both camps are right in this argument - Neck pickups hold their uses for certain things, and a guitar with two pickups is more versatile because of this...but if you know what sound you're after, and a single p/up gives you that sound then why overcomplicate with two pickups? especially if you have other guitars you can use when you need a neck pickup :)
And i think tom's "rawk" comment was a touch sarcastic :drink:
Quote from: deg0ey
I guess it was.. but its also partially true! Less fuss more rock :P
