Seriously Tempted To Get A 7-String
Started by Muttley, July 26, 2006, 11:15:31 AM
Sifu Ben
Phantom_Orchestra
I would go for th Yamaha AES-RS7, i have the AES-AD6 (6 string), and the guitar is truly is amazing, great design, always in tune, and a tone all its own. I cant say enough about them
http://www.yamaha.com/guitars/products/productdetail/0,,CNTID%253D60017%2526CTID%253D600012,00.html
Muttley
Quote from: Phantom_OrchestraI would go for th Yamaha AES-RS7, i have the AES-AD6 (6 string), and the guitar is truly is amazing, great design, always in tune, and a tone all its own. I cant say enough about them
The downside of those are:
1) Only one pickup
2) Farking ugly looking
3) See 2.
Muttley
Muttley
Quote from: Crazy_JoeCheck out an RG7321, fixed bridge, black, 5pc wizard neck!
Perfect 7 string.
http://www.machinehead.co.uk/images/ibanez-jpg/rg7321lg.jpg
Or if the fixed bridge is not a necessity, then go more upmarket into the Ibanez prestige series and get the RG1527, same look as the one above really except has an edge pro trem, but has a lot of professional features.
http://www.machinehead.co.uk/images/ibanez-jpg/rg1527-lg.jpg
I already have an Ibanez (JEM7BSB), so I'd like to get something a bit different really.
Muttley
n_mountain
How much would you like to spend?
Muttley
Quote from: n_mountainHow much would you like to spend?
Probably around £600.  But if I saw something I really liked that cost more I'd just have to do a bit of saving first.
Muttley
genocidal tendencies
Haven't played one myself, but have you considered a maverick? I've heard a lot of good things about them recently.
http://www.guitarpeddler.co.uk/acatalog/Maverick_Guitars.html
The species 7 string is £450, which means if you stretch to £650 or so you can BK it.
deg0ey
The maverick X series look quite nice - like an explorer but cooler...But the rest of them look horrible imo
I like the look of the Schecter Omen 7, but I've never played one which doesn't help...The LTD 7 strings might be worth a look, but again I've not played them
Sifu Ben
I played a Macerick X1 recently and it was really nice, but the neck seemed ridiculously long for some reason  :?
The Species 7 looks quite cool for a 7 really as it's somewhat understated and has no unecessary bells and whistles (always a plus IMO).
If you want something really different from an Ibanez then you can still find the Dean Evo 7 at some places
http://www.singingchicken.co.uk/item5020.htm
The guys on the Dean forum speak pretty highly of it, but image wise it's not really what you think of when you think 7 string (but that does give it it's own coolness).
Why not go for a baritone? Six strings is all you need.
Sifu Ben
I think it depends on how you view a seven string really. If you just view it as a way to get low end chug, then a baritone is probably better, but if you want a guitar that gives you low end chug WITHOUT losing high end, that allows you to play your standard chord voicings , along with extended scales and arpeggios in one position, then it's a useful instrument
deg0ey
In my opinion, 7 strings are incredibly versatile - in theory. In practise I've found the neck too thick to do much but chug away at it, as the strings are further apart so it's even harder to play as a 6 string...and for that reason mine is still sat on the shelf (well not a shelf, but you get the idea).
I thought I'd use it a lot when I got it, but I don't...But actually now I think about it, the biggest reason I don't use it is the cheap epiphone pickups :lol: Unfortunately I can't afford BKs for it right now, but the stock pickups are really weak - and you can hardly hear the bridge pickup at all - not the best on a guitar made for chugging :P
blue
i have a seven string, and the thing that has surprised me most about it is that it's really good for finger picking!  i use it for most of my fingerstyle playing.  it also has a great sound for funk rhythm guitar.  i think it's a pity that most 7 strings seem biased towards metal, as there are a lot more possibilities there.
i would actually agree that if metal riffing is your aim, a baritone 6 string would be better, although they also sound fantasic at surf music!  someone has to make a 7 string telecaster.  or maybe a 7 string gretch?
Muttley
Quote from: Sifu BenI think it depends on how you view a seven string really. If you just view it as a way to get low end chug, then a baritone is probably better, but if you want a guitar that gives you low end chug WITHOUT losing high end, that allows you to play your standard chord voicings , along with extended scales and arpeggios in one position, then it's a useful instrument
That pretty much sums up exactly what I'm hoping to use it for.  :)
Muttley
Quote from: bluesomeone has to make a 7 string telecaster.  or maybe a 7 string gretch?
You mean like this one?
http://www.gbase.com/Stores/Gear/GearDetails.aspx?Item=1500541
