single coil pickups
Started by Davey, July 30, 2006, 04:06:50 PM
Tim
Doing an 'emg' style baseplate isn't a problem, it just means moving the eyelets to either end of the coil near the mounting screws.It does however make fitting a cover on very tricky so they're better off tape wrapped.
Tim
Davey
i think this was the fastest turn around in pickup history.. i dont know if i had the pup for 10 minutes heh =/
it should be @ BKP around friday or monday
i kept the purchase docs, but sent the box as i recieved it. the note you said i should add with the pickup is under the pup itself.
thanks for the help guys!!
My two Trilogys in my Charvel were the special thinner type fit.
