Metal Pickups for my Epiphone LP
Started by Liquid, August 01, 2006, 05:04:31 PM
Siadern
I've tried Warpigs in 2 guitars, a BC Rich with a Nato (Eastern Mahogany) body and a my Gibson Les Paul.
In the BC Rich they improved the sound by a factor of 10. Powerful, full, with plenty of definition to the tone even when tuned down. In the Les Paul I find myself turning down the Bass and Mid and turning up the Treble, but I still can't get as good a sound. Plus it just doesn't sound like a Les Paul any more.
The other thing is, you said you want 'tight bass' with 'nice highs for solos'. This isn't the Warpig in any guitar let alone a Les Paul. Sounds like you were right on the money when you mentioned the MM.
Sinner, Irish Tour, Mothers Milk, Trilogy, Mule, Black Dog, Mississippi Queen, Warpig
Liquid
Thanks guys, you've all been really helpfull, I'll be ordering my Miracle Man ASAP  :)
Before I do get it though, I was wondering if there would be any problems when I later got a lower output pickup for the neck? I've heard Calibrated sets make for 'Even' switching between bridge and neck, but If I had a MM in the bridge and say a Mule or a Cold Sweat in the neck and I wanted to switch from a distorted (Bridge) part to a clean (Neck) Part would there be a Jump in volume or anything? Sorry if this is a stupid question, I just want to be sure. If it will cause problems I might go for a calibrated MM set instead (Though it will mean a much longer wait before I get it)
Peter Antal
Quote from: LiquidI've heard Calibrated sets make for 'Even' switching between bridge and neck, but If I had a MM in the bridge and say a Mule or a Cold Sweat in the neck and I wanted to switch from a distorted (Bridge) part to a clean (Neck) Part would there be a Jump in volume or anything?
Not really a volume jump but rather a jump in drive and sustain when you switch to the bridge pickup on the overdrive channel.
Liquid
So there wouldn't really be a problem unless I was switching from say Clean Bridge to Clean Neck or Distorted Bridge To Distorted Neck?
Liquid
Can Anyone answer this? I really want to get a BKP as soon as possible but I want to make sure it wont mess up my sound  :P
Liquid
Last question, promise  :P
Would it be possible to get a calibrated set of an MM and CS? And would it make a big difference over getting an MM now and a CS later?
CaffeineJunkie
when you order, tell tim that they are going into the same guitar and you want them calibrated and he'll do it for you :D
Liquid
Wow, gotta love the service here  :D
Would there be a big difference between a cali'd MM and CS set and a non calibrated set?
Apparently there is a difference between calibrated and non-calibrated. I ordered my set of Mules at different times (couldnt afford it all at once :lol: ) and they still sound great together, dont know if it could really get much better if I got a calibrated set but you never know!
Liquid
That's the problem I'm having too. I Can either get an MM now or save up for a calibrated set, Problem is, I want my MM now!  :P
Liquid
okay, I've decided to get the two together even though I'm going to have to wait :(
So for the neck, which BK Humbucker do you think has the best cleans and would work well in the neck with a Miracle Man in the bridge?(Never mind distortion for the moment)
The neck Mule sounds really good for clean and bluesy type playing, I dont really like hi-gain on it though, its not defined enough when you pile on the gain (at least in my LP it isnt).
Liquid
What about the Miracle Man in the Neck? I know it's supposed to be a Metal pickup, but If I was to get a calibrated MM set then how would the cleans be in the neck?
Liquid
I sent a PM to Tim and decided to just go with a Miracle Man for the bridge now and get another BK for the neck in the near future. I just completed the order for a Black covered MM (50mm Spacing, 2 Conductor Wiring) a few minutes ago.
I just wanted to thank all you guys for helping me decide on what to get, and If I can get my recording setup working, I'll let you all know how it sounds in the Players section  :D
